Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 02-25-2012, 12:39 PM
melissaisdown melissaisdown is offline
Stalling while idling - in park
Hi, I'm new here. Decided to post because I have a 2000 Focus LX. It has 129,000 miles on it. Just replaced the motor mounts, and two days after I get it back from the shop it starts to stall as soon as I put it in park (can't even idle in park 3 seconds)
Sometimes the check engine light comes on, sometimes the oil light blinks.
I'm not sure if the mechanics bumped something or messed something up in replacing the motor mounts or if needing the mounts exacerbated the stress on some other parts.
I just replaced the mass air flow sensor around May of '11. Oil/filter was just changed and air filter is < 2 yrs old.
I've been reading that it may be an oxygen sensor or a hole in a pcv valve. But one thing is irking me. Whenever I took it to the dealership last spring to replace the mass air flow sensor, the mechanic told me there was a small tear in a hose (didn't say which one) and that he put tape on it.
Any ideas at all would be helpful. Thank you!
Old 03-09-2012, 08:49 PM
Hungrycat7's Avatar
Hungrycat7 Hungrycat7 is offline
Re: Stalling while idling - in park
Certainly sounds like a vacuum leak. Some can be like finding a needle in a haystack. I would start with the PVC hose. I know they are a constant problem with the Focus. Had the same with my 2002. Replaced many things before I found a needle sized hole in the bend on the hose.
Old 09-11-2012, 09:29 PM
MRTRUEVALUE MRTRUEVALUE is offline
Maybe idle air control valve, looking to replace mine on 2002 focus. Will not idle or stay running.
stalling while idling 2002 envoy westsideloxx Envoy 0 12-21-2005 07:08 PM
stalling while idleing atl_chevyrider Cavalier 1 09-12-2005 09:32 PM
choaking and stalling while idling legend04 Cavalier 0 11-28-2004 06:22 PM
96 Standard Geo tracker stalls while idling shellpurr General Discussion 7 11-20-2004 02:10 AM
'89 Cavalier stalls while idling 89cavalier Cavalier 11 08-08-2004 03:10 AM
