Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 02-23-2012, 01:18 PM
mark4674 mark4674 is offline
Angry Help.. p0355
car was pulling code.p0308. Found water in plug well, also some oil in some of the others. Went ahead and change the valve cover gaskets and put new motorcraft plugs. Replaced the coil on #8.
Now I am pulling a code p0355, and still has a miss.
2001 LS 3.9..
Old 02-23-2012, 01:26 PM
joegr joegr is offline
Re: Help.. p0355
Check coil #5 closely. #5 is the front one on the left (driver's) side. Particularly, check to see if it is correctly plugged in and the connector is okay. Make sure the plastic latch isn't broken. The code that you are getting now most often means a problem on the primary (low voltage) side of the coil. Also check for any damaged wiring.
The Following User Says Thank You to joegr For This Useful Post:
mark4674 (02-23-2012)
HELP.. Need help 96 Cavalier Auto Can drive forward but no reverse andrew_baggins Cavalier Problem Diagnosis 3 11-18-2010 02:27 PM
Impala car chassis help, Help me identify so I can sell them axujo Cars/Parts for Sale/Exchange 1 02-29-2008 12:25 AM
I need help anyone that knows about Wastegates help me out Phantomsrt4 SRT4 12 11-26-2007 09:57 PM
HELP!! can anyone help me?? speeddemon92 Car Modeling 2 11-06-2007 11:54 PM
need help with a project can u help squeak205 205 1 09-13-2007 10:27 AM
