Two new problems: Ignition switch?
Hi guys,
I'm happy that I finally got to drive my GP again! I had forgotten how good it feels. Unfortunately I noticed a couple of problems, one with the ignition switch and one more still with the steering. 1.- When I turn the key to the start position, lights will work as usual but the engine will start to turn over after about a second. It doesn't happens all the time, sometimes it will start to turn over as soon as I turn the key. Any clues on this? Do you think the ignition switch could be acting up? I don't think I have other electrical gremlins which could point to the switch being bad. 2.- After all the work with the steering system, it's working good. The chattering noise is gone but I still have some whining coming from the pump which goes up and down with the revs and is more noticeable after a cold start in the morning. No big deal it's been like that even after 3 replacement pumps. Checked the fluid level and is OK. I drove the car for a few miles until it reached normal temp. Checked the fluid again and as soon as I opened the cap I could hear air escaping from the reservoir (seemed to be under pressure). I will check the clamps to make sure they are tight. Any thoughts on this? Thanks in advance, Oscar.
1995 Lincoln Town Car 4.6 Signature 1997 Pontiac Grand Prix GT 3.8 2000 Ford Windstar SE 3.8 |
Re: Two new problems: Ignition switch?
So I never got any replies but I figured it out.
Since my car hasn't showed any electrical gremlins I just kept googling for ignition switch problems until I found another way to spot one. Can't remember if the suggestion was from this forum or another; sorry for not giving credit to whoever posted such thing. The DRL's normally turn off when the A/C is being used on any of the 1-4 speeds. My blower motor works OK but since I disabled the DRL's to install HID lights I never spotted such thing. I re-enabled the DRL's and tested with the blower speeds and surely they turned off. Now I know I'm in need of a new ignition switch... The steering pump whine, I still haven't figured out but I can live with it. This morning I replaced the serpentine belt (930K6 or 935K6 will work fine in these cars) and noticed the water pump makes a squeaky noise when rotated counter clockwise but will not do it when rotated clockwise. The pump is relatively new, I bet it has less than 10k miles on it and the pulley has no movement at all. Anybody thinks this could be a problem or is it normal?. Oscar.
