Old 02-22-2012, 09:11 AM
sarahecrisp sarahecrisp is offline
1997 Lumina Won't Start
I have a '97 chevy lumina. I just got the oil changed and the radiator flushed out about three days ago (which I had JUST gotten done three months ago)....
This morning it wouldn't start. It coughs a bit at first for a split second and then just starts clicking over and over again. The oil and engine light are now on, randomly....we tried jumping it with no success....what could be wrong??
Old 02-22-2012, 09:12 AM
Re: 1997 Lumina Won't Start
Note: The volt light came on too
Old 02-22-2012, 12:50 PM
rkvons's Avatar
rkvons rkvons is offline
Your volts light comes on when there is no voltage being generated by your alternator. Your oil light comes on when your oil pressure is too low. Both of these conditions will be present when your engine is not running. You have to troubleshoot it from the beginning. You need to see if there is spark and fuel. Check your fuel pressure. Try spraying starting fluid in the intake while cranking and see if it makes a difference.
97 Suburban won't start, runs with starting fluid rtalnadge Suburban 6 08-30-2014 04:15 AM
1990 lumina won't start w/new cps/ign mod carkid7 Lumina 1 07-30-2010 11:42 AM
1997 Lumina won't Start MultiLuminaowner Lumina 7 06-25-2010 02:12 PM
92 Lumina Won't Start ICM Voltage Brndo Lumina 9 05-02-2010 11:37 PM
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 03:20 PM
Tags
1997 , battery , chevy , lumina , start
