Old 02-21-2012, 11:01 AM
smackerquacker smackerquacker is offline
2002 LeSabre leaking coolant somewhere?? Intake?
In the morning a small wet patch under the vehicle. I put it on stands and let it idle for an hour and nothing. Backed up and there it was like it pooled somewhere and ran off when I moved the vehicle. Oil looks ok. Did just replace the thermostat about a month ago. Heater is working fine. I can kind of smell antifreeze in the cabin area as well as engine compartment but nothing overwhelming. Windshield is not getting slimy like heater core is leaking. Never noticed this until we changed the thermostat. Oh yeah about 130,000 miles. If it is that intake gasket is it obvious to find. I can't seem to locate a wet spot anywhere.
Old 02-21-2012, 01:36 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 2002 LeSabre leaking coolant somewhere??
A cooling system pressure test would be helpful to locate this leak. Inspect around the coolant elbows on the passanger side of engine, also upper intake and throttle body gasket and water pump.
The Following User Says Thank You to gmtech1 For This Useful Post:
smackerquacker (02-21-2012)
Old 02-22-2012, 11:37 AM
It appears to be that plastic bypass elbow that goes into the tensioner. Do those form leaks very often or is it a common problem?
Old 02-22-2012, 01:39 PM
gmtech1's Avatar
Yes, very common. I see you found info on another thread, now you know, do NOT use the aftermarket parts!
Old 02-22-2012, 02:02 PM
Yes I saw that about the aftermarket parts. I already called the local dealer and they have 6 in stock. How much coolant will I lose if I don't drain any.
Old 02-22-2012, 02:09 PM
maxwedge maxwedge is offline
A990 racer
Too much.
2002 SE leaking coolant jamc204 Grand Prix 2 06-17-2010 08:56 AM
99 LeSabre 3800 3.8 coolant leak? Head gasket? Lower intake gasket is leaking.HELP!! chubbygoatboy LeSabre 10 01-03-2010 08:49 AM
'94 TS 3800: HUGE coolant leak - and other fluids jarl Trans Sport 23 10-31-2009 07:53 AM
Small Coolant Leak/Burnt Coolant Smell Through Heater??? Please HELP ASAP! NebulaD Sable 6 04-08-2007 09:50 AM
correct operating temp for a 2001 lesabre?... and coolant leak RustX7 LeSabre 4 04-02-2007 03:58 PM
