Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 02-21-2012, 10:33 AM
decmav decmav is offline
Question 97 jimmy intake gasket replacement help needed
im replacing the intake gasket on my 97 jimmy 4x4 4.3 and my question is after the repklacement do i have to have the scan tool to reset it and do i have to repressurize the fuel system? thanks in advance
Old 02-21-2012, 01:40 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 97 jimmy intake gasket replacement help needed
Not sure what you would "reset" after the intake job. As far as the fuel pressure, a couple of key cycles to run the fuel pump will pressurize the fuel system.
Old 11-04-2018, 09:16 AM
mikehuggins873 mikehuggins873 is offline
no you should not need a scan tool to reset anything unless you need to erase some dtcs fuel pressure will or should repressurize its self with a few key cycles
Old 11-04-2018, 02:31 PM
maxwedge maxwedge is offline
A990 racer
Mike, good info but this thread is 6 years old, please check that first, thanks.
99 Windstar 3.8L Replacing Intake Manifold Gaskets dariem Windstar 8 03-21-2015 05:22 PM
Replacing LIM Gasket TIPS mpit91 Grand AM 5 01-31-2012 02:53 PM
help with lower intake gasket replacement juanito115 Problem Diagnosis 6 08-30-2008 11:48 PM
Need Valve cover gasket replacement help leafadawn Rodeo | Passport | MU 4 12-11-2006 06:02 PM
Intake manifold gasket replacement help! speg80 Alero 4 05-04-2006 11:31 AM
