Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 02-21-2012, 07:34 AM
pateez pateez is offline
Unhappy hello.help with this dodge
im going to try to do this in a short version.mil light came on.noticed i had more heat coming from passenger side than drivers side.noticed i had a leak in the radiator black plastic housing peice had radiator replaced.light still on noticed i had blown 39 fuse replaced it light came off...yippie except the heat is the same.hot on passenf
ger vents much cooler on drivers.now what could this mean..any advice would help thanks patti
Old 02-22-2012, 07:15 PM
jamesslcx jamesslcx is offline
Re: hello.help with this dodge
Pateez, the truck may have a blockage in the ducts or possibly a door or valve not opening like it should.
Old 02-29-2012, 04:10 PM
Levithan9 Levithan9 is offline
Do an Evac and Recharge on the A/C system if you have the equipment. I've learned the hard way several years ago that on dual-climate systems that heat on one side and cold on the other can be caused by low freon in the A/C system.
You didn't say if it was dual climate, so this advise is based on assuming that it is.
Old 02-29-2012, 05:45 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
What year Dodge?
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Need serious help with Dodge Dakota DodgeDak Dakota 4 10-16-2011 12:41 PM
Need help with 4.7L -2000 dak McCowan Dakota 1 11-08-2010 11:15 AM
help with a 92 spirit cooling fan backyardmec_an_ic General Discussion 1 10-30-2009 08:57 PM
need help with 1987 dodge ramcgarger aztekdaddy Ram Pickup | Ram SRT10 1 11-09-2007 07:36 AM
help!!!!! i need help with this supra envydisqbanpapi General 0 06-20-2004 12:58 AM
