Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 02-20-2012, 07:51 PM
budguy007 budguy007 is offline
Unhappy 02 ram 4.7L engine noise
I have a 02 Ram 4.7L with just about 100,000 miles thats got a slight engine noise when motor is cold. Once the motor warms up the noise goes away. I buddy of mine says its dirt on the oil feed to the timing chain and says to put a little trans fluid in the oil and drive it abit and then drain the oil. Any ideas of what the problem is and how to clean it. I dont trust putting trans fluid in the oil.
Old 02-21-2012, 01:26 PM
jamesslcx jamesslcx is offline
Re: 02 ram 4.7L engine noise
bud. I would try Marvel Mystery Oil or Risolone before trans fluid for a gentle cleaning. Run this for a while and change your oil with a good filter. I recommend using a Mopar filter. These engines are sensitive and pretty high tech and will not tolerate neglect. Since your engine only makes noise when cold it could be the filter also, hopefully nothing more serious. What kind of oil and filter have you been using? At what interval? Hope this helps.
Old 02-21-2012, 05:48 PM
DeltaP DeltaP is offline
I agree, Tranny fluid does not lubricate.
Old 02-28-2012, 09:06 PM
lakefork's Avatar
lakefork lakefork is offline
i have a 03 ram 1500 4.7 it does the same thing its is probably the camshaft and valves dont know what to do about it since it goes away i would not worry about it
Need help with 4.7L -2000 dak McCowan Dakota 1 11-08-2010 11:15 AM
2002 1500 Ram 4.7L Engine Knock bcownie Ram Pickup | Ram SRT10 0 07-08-2010 11:51 AM
2002 1500 Ram 4.7L Engine Knock bcownie General Discussion 0 06-22-2010 09:53 PM
90 Caprice lower engine noise? jomo3423 Caprice 4 04-18-2009 06:23 PM
2002 ram 4.7L engine swap RCAID99 Ram Pickup | Ram SRT10 0 07-07-2008 09:00 PM
