View Poll Results: How to fix PO304
Where can I get repair manuel for 08 Taurus X 0 0%
Where can I get diagram of the 08 Taurus X 3.5 motor 0 0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
Old 02-20-2012, 11:25 AM
movaughn movaughn is offline
08 Taurus X Code PO304
2008 Ford Taurus X SEL 3.5 with approx 100k new oil change previously the truck ran great; I have replaced cylinder 4 with a new spark plug and switched the cylinder 4 coil pack with the cylinder 5 coil pack. I am still getting a PO304 cylinder 4 misfire detected. I never saw any codes prior to the truck running rough yesterday. I scopped and found; PO351, PO352, PO354, PO304 I cleared the codes and the only one showing now is PO304. I have been searching for manuels and help with diagrams with no success. Any help would be appreciated.
Old 02-20-2012, 12:53 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 08 Taurus X Code PO304
You should be able to find a Haynes or Chilton repair manual from local parts stores. If you're looking for something more along the lines of a Ford Factory Service Manual, you might consider a subscription to Alldatadiy.com. The information they have for modern Fords is directly from the factory service manual. And if you are looking for just a diagram or two related to the ignition system for your Taurus X, send me a Private Message with the request and an e-mail address and I'll send you a PDF or two.
Would you be up for the challenge of moving a couple of fuel injectors around, similar to what you tried with the spark plug and coil pack? Or do you happen to have access to a cylinder leak down tester?
-Rod
Old 02-23-2012, 07:36 AM
-Rod
Rod,
I have searched far and wide for the Chilton and Haynes manuels only to be told they don't make them for my vehicle. I have since replaced all of the spark plugs and there is no change. I will check out Alldatadiy.com I payed for the on line RepairSurge and found it was just a great place to park my money. As for moving the fuel injectors I will try I found the wires are very short
Thanks Again for your help Rod,
Movaughn
Old 02-23-2012, 08:33 AM
tempfixit tempfixit is offline
For a online manual try your local library website, see if they have EBSCO HOST, if so they should have a link called ARRC (Auto Repair Reference Center). It is in the line of a Haynes or Chilton manual.
You could also call the Library and they should be able to tell you if they have it available.
The Following User Says Thank You to tempfixit For This Useful Post:
movaughn (07-07-2012)
Old 07-07-2012, 08:10 PM
Thanks All,
The problem was the computer and it was under warranty.
Misfire Code nozzle936 Silverado 8 12-23-2009 09:37 AM
2000 2.4l Sonata code po304 failed inspection greenman2007 Sonata 1 05-21-2009 01:44 AM
trouble code PO304 venture 1998 venturenot Venture 5 04-21-2008 12:34 PM
codes PO304 and PO306 ? Dorians Windstar 2 08-17-2005 08:29 AM
Code PO304 # 4 plug misfire Dcrusoe Venture 2 01-31-2005 05:44 AM
