Old 06-02-2003, 04:56 PM
phantomhitman phantomhitman is offline
Question diecast help
since i have seen many great plastic kits on this board i want to ask you guys about a diecast question. i am working on a few 1:18 scale diecast customs. i am wanting to make side skirts and fender falres and various other "kit" items. what would be the best way to mold and attach these peices for use on a diecast car? thanks for any help.
Old 06-02-2003, 06:13 PM
freakray freakray is offline
AF Modelrater
Welcome to AF
You may want to ask the guys in the Diecast forum about this, they may be able to tell you the best how to modify diecasts.
Ray
AF User Guidelines
Old 06-02-2003, 06:16 PM
primera man's Avatar
"P-Man"
The diecast forums should be able to help you on this one
View All My Models Here.
Old 06-02-2003, 07:20 PM
thanks guys ill try that out
Old 06-02-2003, 08:11 PM
Midnight Racer's Avatar
I'm guessing you can use putty to make the side skirts.It should stick to metal.
Old 06-03-2003, 09:00 PM
thanks ill try that out. someone else from another forum told me about this putty made by tamiya.
Old 06-04-2003, 03:14 PM
I would try automotive putty since its made for metal.Tamiya is mad for plastic.
Old 06-05-2003, 04:47 PM
djAkira36's Avatar
djAkira36 djAkira36 is offline
Send a message via AIM to djAkira36 Send a message via Yahoo to djAkira36
I've done my share of diecast modification, Bondo works ok but you have to be VERY careful handling the car afterwards especiallly when sanding. I've gotten the best results using JB Weld, It's a putty that is specified for metal and works really well with diecast. But, you have to be really patient and precise when using it because sanding it is a bitch, so you have to get as close to the desired shape before it dries. Also, make sure whatever surface you apply it to is sanded down to the bare metal so you'll have to prep using low grit automotive sandpaper... I usually apply it generously, then as its drying, I use a razor blade to shape it. Once its dry I smooth it with a wetsanding using high grit automotive sandpaper. Same thing goes when using bondo.
SURGEON GENERAL'S WARNING:
APC products may cause CANCER!!!!!
Old 06-05-2003, 09:23 PM
wow, jb weld. i thought this was for making engines stay together i might try that. thanks
