Go Back   Automotive Forums Car Chat > Ford > E Series
E Series Forum covers questions and discussions regarding Ford E-150, Ford E-250, Ford E-350, and Ford E-450.
Old 06-02-2003, 03:50 PM
gregworth gregworth is offline
Unhappy 98 e-150 brakes pull
I have replaced calipers, rotors, and brake pads and still the brakes pull hard right.
The brakes were OK for a couple hundred miles now are pulling again.
Any help would be appreciated.
Old 06-02-2003, 08:09 PM
pcv pcv is offline
What's the milage on the van.f it is really high, Id replace the front brake flex lines and bleed the system.
NOTHING LIKE AN OLD CAR.
Old 06-03-2003, 09:03 AM
The van only has 44,000 miles on it.
Old 04-18-2004, 08:20 PM
dxrflyboy dxrflyboy is offline
Re: 98 e-150 brakes pull
It's a good possibility that the LF hose is blocked. Pull the LF caliper off the rotor, apply the brake, and see if the piston moves. Even if the piston does move, the blockage could be causing the LF caliper to apply slower than the RF, causing your pull. Does the vehicle also pull to the left momentarily after the brakes are released? That would reinforce the possibility of a blocked hose.
Old 05-09-2004, 09:47 AM
Slade901's Avatar
Slade901 Slade901 is offline
Banned
Try to lube any caliper bolts, slider bolts, the metal surface of the brake pads that comes in contact with the caliper and caliper mounting bracket. You may need to file to make sure it's smooth.
