Go Back   Automotive Forums Car Chat > Chevrolet > Express | G Van
Old 02-18-2012, 09:57 AM
moliva1568 moliva1568 is offline
Coolant leak
I have a coolant leak and have been trying to track it down. I don't see it at the water pump, from the radiator, or around the reservoir. I was able to get some video and a few pics of where it seems to be coming from. All leaking coolant is appearing on the L hand side under hood. Please take a look and hopefully give me an idea if i've found the likely source or a result of the real culprit. The heat works but the other night it wasn't getting hot. I noticed the coolant was low and added some. Now it's low again and heat isn't there.
It's a 1991 G20 with 350 and AC.
Video from inside van (click on it to view)
Pic from inside
Pics from under hood
Thanks
Old 02-18-2012, 02:04 PM
Re: Coolant leak
Figured out it's the heater control valve. Purchased a new one but can't get the old one out. Any tips? should i cut the hoses or try to save them?
Thanks
Old 02-18-2012, 02:28 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Coolant leak
Those hoses don't look too bad. Usually the hoses get the most wear right where the clamp goes. If there is extra length, you can trim-off the last half-inch so the new valve an the hose clamp sit on fresh rubber instead of the squished-down rubber from the old valve.
But if in doubt, use a new hose. Typically some universal straight hose will do. It's cheap to buy. You can always buy some extra length with a couple of extra clamps just in case you need to do an emergency repair when you are travelling.
Old 02-18-2012, 02:32 PM
Re: Coolant leak
They are a pain to try and get off. I was afraid to cut them, in particular the one going towards the radiator because of the curve and finding a replacement. But it's so tight in there i have way to wiggle them around at all. i may just have to cut it.
(disregard my question on the other thread, you've addressed it here. Sorry)
Old 02-18-2012, 03:29 PM
Re: Coolant leak
Finally got it out and it only cost 2 hoses. I don't see any visible damage compared to the new one. Is it safe to say whatever failed might have been internal?
Old 02-19-2012, 12:01 PM
Re: Coolant leak
Can someone tell me what is the correct heater hose size? 3/4 or 5/8
Old 02-19-2012, 12:19 PM
aleekat aleekat is offline
Re: Coolant leak
Just take your new valve with you to the auto parts store. Then just get a hose that fits snugly.
Old 02-19-2012, 12:52 PM
Re: Coolant leak
is it safe to say it would also be snug enough for the heater core pipes?
Thanks
Edit: disregard this question. Looking at valve itself shows the different diameters
'93 lesabre coolant leak behind the throttle body CAMFLIGHTRN LeSabre 7 01-21-2012 02:49 PM
'94 3800TS: power steering and coolant leaks jarl Trans Sport 1 08-03-2010 04:02 PM
'94 TS 3800: HUGE coolant leak - and other fluids jarl Trans Sport 23 10-31-2009 07:53 AM
2000 Blazer lower intake plenum coolant leak Sedatedbylife Problem Diagnosis 8 06-27-2009 10:20 PM
98 Grand Caravan 3.3L Coolant Leak hooperkj Caravan | Voyager 4 04-22-2009 04:17 PM
