Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 02-17-2012, 09:51 PM
2001ImpalaGuy 2001ImpalaGuy is offline
Arrow Cant go over 30 mph!
Hello,
I recently purchased a 2001 Impala, welcome to the club huh?, the issue is that a few weeks into driving the car it began to have some issues. The car cannot accelerate over 20 mph without making a grinding noise and it cannot go over 30 mph at all while on "D". The same thing for "1" and "2", however, when I put it on "3" it can go up to about 55 mph. I 100% thought it was the transmission, but I read a few posts online and saw some people saying it could be the mass air intake, others saying it could be the fluid and that I should flush it, and others saying it could be a mal-functioning cat. converter. So now I am more confused than ever, if I take it to the mechanic they're going to ask what do I think is wrong and when I say I think it's the tranny - that's what it's going to be because well they hear a cash register going CACHING! Well thank you in advance for the help.
Old 02-17-2012, 09:58 PM
Re: Cant go over 30 mph!
Also says it can be the bands need to be adjusted or the fluid pump.
HELP ME, PLEASE!
Old 02-18-2012, 01:28 AM
oldblu65's Avatar
oldblu65 oldblu65 is offline
You need to have it scanned for trouble codes . Most of the major auto parts chains will scan it for free . When you have a code , you likely will have a better idea of what is wrong with your Impala . Take the code and go to www.obd-codes.com . You can then see what the code is telling you and go from there . Good luck !
" Sometimes I grow so tired "
Old 02-18-2012, 11:19 AM
j cAT j cAT is offline
HELP ME, PLEASE!
as was mentioned get the DTC failure codes pulled and post here.
seems you do have transmission problems . these transmissions required synthetic transmision fluid but DEXRON III was used and with no fluid replacing every 40,ooomi they failed at a high rate. just after the 36,ooomi warrantee period.
I would go to a transmission shop to have them get the drivetrain codes and do a pressure test. with that info they will be able to tell you whats going on. my guess a 2,ooo.oo rebuild.
thats just a guess. could be a simple valve failure etc..
if the fluid is dark and has a bad burnt smell its gonna cost ya.
Old 02-18-2012, 02:57 PM
No engine light and no code showing up - took it to AutoZone.
Old 02-18-2012, 02:59 PM
Now that you mention it, it does smell bad - kind of like burnt oil but I thought that was another problem completely.
I thought it would take a pretty good stab at my pocket book.
Old 02-18-2012, 09:22 PM
To add confusion to the puzzle; my wife attempted to turn it on - two seperate occassions - and it would not start. HOWEVER, just a few hours ago, I turned it on fine and drove it past 40 without a problem - I had to slow down and stop due to a stop sign. I do not want to push it too hard because it's the first time it goes over 40 on "D" so I don't want to mess it up more. So now I am really puzzled.
I explained the problem to a guy in the shop, he said it could be my Transmission's speed sensor but we could not replicate the problem because it was driving fine now. WTFudge!?
Old 02-19-2012, 07:34 AM
if you read my post earlier it says go to transmission shop for diagnosis. pressures//drivetrain codes.
auto zone can only get engine codes and possibly some other codes. drivetrain codes require an expensive OEM type.
cant find drum brakes for 62 nova m3gas3th Nova 3 02-21-2012 07:19 PM
Repairs after roll over? PCruiseW SC/SL/SW 8 02-25-2009 07:57 AM
Cant go more then 60 MPH what the heck!? dagwood387 Tacoma 12 11-02-2005 09:27 PM
Shaking over 65 mph- what is this bbegen Riviera 8 04-09-2004 06:03 PM
