Old 02-17-2012, 07:42 PM
TylerSarah TylerSarah is offline
87 chevy pickup
when i got my 87 chevy pickup it had a 305 in it and i decided to put a vortec 350 in it. Which i had to get a conversion manifold from GM so i could put the throttle body on. but for some reason it will start shaking around 1200-1400 rpm, kinda like a miss. when its cold and in open loop it as a erratic idle. Its running really rich and bad fuel mileage, i took it to two shops and said the manifold was leaking and told me to put silicone on the intake gaskets and now i can spray B-12 or brake cleaner and i cant find a leak.
Everything is replaced like Engine, Throttle body, distributor, ecm, map sensor, tps sensor, iac sensor, egr.
Also at highway speed it will turn the check engine light on but for some reason i cant read the codes. When i plug the code reader in it says that its basically not connecting.
Give me a direction please. Im clueless
Old 02-18-2012, 09:09 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 87 chevy pickup
Jumper pin A & B on diagnostic connector and read codes from check engine light.
Post back code.
All sensors pluged in and woking right?
Make sure map sensor is getting proper vacumn.
And tempt sensor is working.
And both reading right to PCM.
MT
timing a 96 chevy pickup 350 vortech pjr1957 C/K 1 01-26-2004 11:00 PM
timing a 96 chevy pickup 350 vortech pjr1957 C/K 4 01-07-2004 07:12 PM
Erratic timing on a 89 4.3L chevy pickup Service Center C/K 1 09-10-2003 02:33 PM
Timing a 94 Chevy Pickup 2500 series villins3 C/K 5 07-18-2003 01:01 AM
my wicked retro style chevy pickup mentalmickey Car Modeling 13 03-23-2002 05:34 PM
