Go Back   Automotive Forums Car Chat > Buick > Century
Old 02-15-2012, 03:46 PM
KingCobra89 KingCobra89 is offline
catalytic converter issues
I have a 2000 buick century and need the catalytic converter replaced. How hard is it to do yourself? Also ive heard their is a bulletin about the buick regal converters going bad and gm extending the warranty, is their any information about something like this with the century.
Old 02-15-2012, 04:09 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: catalytic converter issues
GM did extend the warranty to 120K miles if you are beyond that you will need to replace it yourself. As for a new one you can purchase a direct fit convertor from most auto parts stores or online. If you have the tools and some basic automotive knowledge you can replace it yourself. The hardest part is removing the old parts especially the nuts that hold the convertor to the manifold. If you decide to do this yourself get a can of PB Blaster and soak the nuts liberally and let them sit. Do it several times.
The direct fit convertors are the easiest as they do not require welding. If you use a universal one you will need to weld it in place. A much harder job. Good Luck!
Old 02-15-2012, 04:13 PM
The car only has 91,000 miles on it. Do you know where to get the warranty information so I can bring it to the dealer and show them?
Old 02-15-2012, 07:00 PM
Pontiac Guy
The best thing to do is to check with a GM Dealer to see if your model was covered by the extended warranty. I know it covered the Regal and Grand Prix but it may have been later model years and the Century may not have been included. Even if you need to replace the converter it shouldn't cost more than a couple hundred dollars.
Old 02-16-2012, 10:20 AM
Tech II Tech II is offline
While you are under on mileage, I believe you are over on time....call your local dealership, or maybe our local GM rep on the board can give you the specific mileage/year interval.....
2003 Escape XLT 3.0 6Cyl 4WD - Catalytic Converter Issue? sophiesmom64 Escape | Maverick | Escape Hybrid 11 01-08-2014 08:26 AM
Catalytic Converter issues jrwalte Escort 12 03-09-2007 10:13 AM
'96 Catalytic Converter Issues GasPriceVictem Yukon 2 05-10-2006 07:28 PM
Straight Pipe Catalytic Converter conversion Austin Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 7 08-09-2004 05:46 AM
Catalytic Converter Fit Issues after engine swap mrnabeehhasan Engineering/ Technical 3 12-02-2002 11:25 PM
