Old 02-13-2012, 09:09 PM
mkvkerala mkvkerala is offline
Dtc p0717
I have one vehicle in which dtc p0717 is setting ,while running the vehicle in 4th gear at that time iss data is getting to zero,i already replaced iss sensor,TCM moudle, but still complaint persist.
advice me
Old 02-13-2012, 10:24 PM
j cAT j cAT is offline
Re: Dtc p0717
advice me
make sure the sensor is correctly mounted flush with the transmission body. check connectors and wiring for damage. if it is intermittent open or short in signal or a low signal you will get this code.
Old 02-14-2012, 04:42 AM
Re: Dtc p0717
i have already checked for intermittence condition and short to ground & short to voltage , and all find normal, also i made a new harness between the 20 way connector to TCM and test the vehicle still there is problem.so i checked the supply voltage to tcm by probing the wire with fluke meter and roadtested,and there is no cutting off the supply voltage while the concern occurs.Also i changed the inernal harness of the transmission and still problem persist.Also i inspected the harnees for any misalignment and input shaft face damages all found normal.
pls reply
Old 02-14-2012, 08:00 AM
Re: Dtc p0717
pls reply
tap into the sensor output and monitor the output signal. using an O scope would be best . if the signal drops out or has a low amplitude/improper shape then the transmission encoder wheel may be broken or damaged some how.
The Following User Says Thank You to j cAT For This Useful Post:
mkvkerala (02-14-2012)
Old 02-15-2012, 11:19 AM
Re: Dtc p0717
hi
As we dont have O scope,i removed transmission again and checked the input shaft and found that input ,shaft came out around 2 mm also i compaired the input shaft so that i confirm that it was the root cause for the complaint.
Thanks for your kind advice
Old 02-15-2012, 01:31 PM
Re: Dtc p0717
hi
thanks for your feedback with this issue . you problem is not all that common here in the states.
with your detailed description of prior work completed , it had to be inside the transmission .
99 venture - code P0717 davlys Venture 2 05-21-2009 04:46 PM
DTC chart for OBD2 bowtiebandit General Discussion 1 10-05-2005 12:31 PM
P0717 kilroypr Grand Prix 0 10-18-2004 09:49 PM
DTC P0172 system too rich bank 1 cobra1 Blazer 1 06-08-2003 04:01 PM
