Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 02-11-2012, 07:13 PM
tkswan's Avatar
tkswan tkswan is offline
Oil pan gasket
2002 LS V8 150k miles.
I would like to hear from someone who has changed, or has information pertaining to changing the oil pan gasket. I have either a bad oil plug, and/or a leaky gasket. If its a gasket i'll replace the plug too.
There is no oil on the sides of the block, so im pretty certain that its the gasket, hopefully not a cracked pan.
There are oil drips on my garage floor away from the plate that sits under the car so my leak is splashing back under the car and i can smell oil burning off the hot exhaust.
I keep my eye on the oil level and since my last oil change i've added a quart of oil twice. The computer is asking for an oil change now.
I would love to read the shop procedure if anybody has it. There is a self service garage in my area where you can rent a bay with a lift. I want to make sure that if i go over there and start this job im going to be ale to finish it, the same day.
Thanks in advance
-tswan
Old 02-11-2012, 08:29 PM
joegr joegr is offline
Re: Oil pan gasket
It's very simple on the V8. You don't even have to move anything out of the way.
Removal
1. Raise and support the vehicle. For additional
information, refer to Section 100-02.
2. Drain the engine oil.
3. Remove the oil pan.
• Inspect the gasket and install a new one if
necessary.
Installation
NOTE: Make sure all gasket sealing surfaces are clean
and dry.
1. Install the oil pan. Tighten the bolts in the
sequence shown in two stages.
• Stage 1: Tighten to 5 Nm (44 Ib-in).
• Stage 2: Tighten to 12 Nm (9 Ib-ft).
2. Lower the vehicle.
3. Fill the crankcase with clean engine oil.
The Following User Says Thank You to joegr For This Useful Post:
tkswan (02-12-2012)
Old 02-12-2012, 10:16 AM
tkswan's Avatar
Re: Oil pan gasket
Removal
necessary.
Installation
and dry.
Wow, looks like the time consumer here is putting the 17 bolts back in.
Thanks for the information.
-tswan
Old 02-13-2012, 01:27 PM
tkswan's Avatar
Re: Oil pan gasket
Removal
necessary.
Installation
and dry.
one more thing. do i have to have it on a lift? will everything clear if i do it in the garage on jack stands? That way i won't have to work on a hot car.
-tswan
Old 02-13-2012, 02:42 PM
Re: Oil pan gasket
IMHO, jack stands will be enough. (It's a shallow pan.)
tkswan (02-13-2012)
2000 GC 2WD - Remove oil pan without removing exhaust y-pipe? jrandallc Grand Cherokee | Grand Cherokee SRT8 0 06-05-2011 08:31 AM
Searching for a Ford Pinto oil pan Mr 14 Prozent Engineering/ Technical 0 05-25-2011 07:01 AM
Oil Pan Gasket? ken_man_1 F Series 8 12-03-2010 07:30 AM
valve cover gasket and oil pan gasket "seeps" georgecarnes Camry/Camry Hybrid/Vista 1 08-14-2004 10:39 PM
