Old 02-11-2012, 05:50 PM
GT55 GT55 is offline
97 blazer in tank fuel pump
Thru several checks I know I need to replace my in-the-tank fuel pump. Is there a way to go from the top and get to the pump in the tank? I heard of folks cutting thru the sheet metal to get to the pump. Sounds like a great idea and a helluva short cut, but where do you know where to cut. Constructive comments needed...
Thanks All
GT
Old 02-11-2012, 06:40 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 97 blazer in tank fuel pump
Thanks All
GT
Best to move the tank on a Blazer.
MT
Old 02-11-2012, 06:55 PM
It's a 4 door S-15 Blazer. I don't understand "moving the tank". Please explain.
Thanks
GT
Old 02-11-2012, 09:36 PM
old_master's Avatar
Advisor/Moderator
It's best to remove the tank when replacing the pump. The pump does not come straight out when removing, you need to jockey it a bit to get the float arm out without damaging it. Be very careful of the vent line fitting on the top corner of the tank. It's very fragile and breaks easily if you're not careful when dropping the tank. Don't waste your time or money on aftermarket pumps, use AC Delco or Delphi only. Far too many problems with aftermarket pumps.
You have to know how it works,
to figure out why it doesn't.
2000 Sonoma Replaced fuel pump ????????? cortervette Bravada 8 12-22-2010 10:42 AM
91 corsica 3.1 fuel pump not pumping miecow Corsica 3 05-04-2009 11:39 PM
Fuel pump problem lmattiso Rodeo | Passport | MU 0 04-25-2009 02:08 PM
Help with Fuel Pump Resister Relay bbaker1985 Grand Prix 1 03-28-2009 09:14 PM
gtp fuel pump? finkk Grand Prix 9 03-13-2009 08:04 AM
