Old 02-10-2012, 07:13 PM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Broken shifter knob button.
I've this little nuisance for a while now, still havent found a good fix. Ive tried gluing it back on with some pretty intense glue, and it still wont hold.
Anyway here is a picture of what Im talking about:
Id like to just replace it, but Im not sure where Id get one besides a salvage yard, and I cant seem to figure out how the thing comes apart. Anyone with more info?
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 02-11-2012, 01:52 AM
pfofit pfofit is offline
Re: Broken shifter knob button.
Mine did the same thing, But my second glue attempt worked for the last several years anyway.
The button gizmo is a one way device, once it goes in, it clicks into place.
Since the button on mine was broken similar to yours, I was able to ( took a bit) reach inside with a couple sharp tools to release the clip an extract the remaining broken bit. Cleaned up both bits to make a good fit and then glue up, after it sat for a while I greased up the inside hole and then while holding my breath and crossing my fingers, gently slide it back in until it clicked and locked.
Apart from that, to release the whole knob there is a U clip, about a half inch wide, in front on the gear shift lever near the bottom of the knob, that holds the whole knob on the shaft. Pull her back as far as it will go. Use a 1/8 sharp flat blade screwdriver to dig in a bit and pry it out to get it started and then grab it with a pair of pliers to remove it. Then pull the knob straight up. That is what a yard will give you.
cheers
If it was easy, then anyone could do it.
shifter knob mikeburrit01 1st Gen 95-99 5 04-20-2010 08:48 AM
auto shifter knob broken petermc Alero 2 06-19-2007 02:53 PM
94 ford tbird broken shift knob button ovets Thunderbird 3 12-26-2006 04:25 PM
99 rodeo shift knob button will not push in ineedhelpplease Rodeo | Passport | MU 2 07-15-2006 01:59 PM
Shifter Knob - Overdrive Button? software23 Car Audio 5 07-05-2003 08:39 PM
