Go Back   Automotive Forums Car Chat > Mitsubishi > Mirage
Old 02-10-2012, 11:29 AM
smeacham smeacham is offline
1990 Mirage No Spark
Posting for a friend, he has a 1990 mits Mirage wouldn't start. No spark from coil secondary. Changed the Coil Still no spark the coil has 12 volts on the inlet. No pulse on ground. Also checked the module and it gets continuity with a 1.5 volt batt jumped from ic to g. I am looking for a procedure to check the Crank position sensor that is in the distributor. it is a 4 wire plug connected up on the fire wall. I think its either the CPS or the ECU both about $300. I don't want to just throw money at it any help will be appreciated thanks,
Steve.
Old 11-18-2013, 01:51 PM
Cali_sWag1231 Cali_sWag1231 is offline
Re: 1990 Mirage No Spark
it could be you cam sensor, and usallay u check the crank sensor with a ohmeter
need urgent help on this old red 1990s mirage soybean24 Engineering/ Technical 1 07-07-2010 01:20 PM
1990 Mirage IllStd Mirage 7 09-05-2007 08:27 PM
1990 Mirage ECU location? rrdstarr Mirage 1 11-13-2004 08:36 PM
1990 Mirage 1.5 clutch chaka Mirage 2 09-24-2004 12:27 PM
body kit for a 1990 mirage Skaterboy Mirage 1 10-12-2003 06:37 AM
