Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 02-08-2012, 09:58 AM
rover5 rover5 is offline
Compression on 2000 monte carlo
What is the compression supposed to be on a 2000 monte carlo 3.4 It is running hot and the heater is not working
Old 02-08-2012, 11:34 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Compression on 2000 monte carlo
You won't find a "spec" for compression numbers. After checking compression on all cylinders, the lowest number should be within 30% of the highest number.
Have you checked for coolant leaks? Sure you don't have a lower intake gasket leak?
Old 02-08-2012, 06:59 PM
How do I check the intake gasket When it gets hot the heat light will come on; you can turn it off and wait a few minutes then the heat hand will drop back down to around 160 or 170 but the heater want heat; and the car want get hot again; you can let it set and idle and the fans will come on and the heater will work good but when you start driving it the heater stops heating and goes cold; the compression on the heads are running from 90 to 125
Old 02-11-2012, 11:10 AM
maxwedge maxwedge is offline
A990 racer
Could be air bound, bleed the system first. BTW 90 is low for that engine at normal cranking speed, throttle held open.
2000 Monte Carlo Traction Control Problem. Gkumler Monte Carlo 12 10-07-2006 02:39 PM
2000 Monte Carlo SS VS. 2000 Intrigue bcook Street Racing 27 04-08-2005 08:12 PM
2000 Monte Carlo LS Tank5410 Monte Carlo 1 10-17-2003 07:07 PM
2000 Monte Carlo SS quarter mile times? 97gsr Monte Carlo 3 07-24-2003 09:48 AM
Toyota Corolla WRC 2000 Monte-Carlo suggestions Mr Mario Car Modeling 14 02-05-2003 09:08 AM
