Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 02-08-2012, 10:12 AM
Rob711 Rob711 is offline
Help: 96 jeep grand cherokee won't start
I have a 96 grand cherokee laredo, and the other day it just wouldnt start. The jeep will not turn over, so i started checking some things out and determined that it was not getting a spark. Since i replaced the distrubitor cap recently i figured it had to be the ignition coil, so i replaced that. Still no go, i tested to see if the ignition coil was getting a spark by using an ohm meter, and nothing.
So something is preventing the spark even getting that far. I do not know much about vehicles, and i have to think it is something in the electrical system (like a chip or something),possibly security system, or NSS. I have come up with these by reading other people having similiar problems.
Any ideas?
Thanks
Old 02-08-2012, 08:20 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Help: 96 jeep grand cherokee won't start
If the problem happened suddenly after the cap replacement, that's what I'd look at first.
With the distributor cap, did you also replace the rotor? Check to make sure that both are securely on.
There are numerous problems reported that are caused by voltage/battery issues. Have your battery checked, and also have a look at the positive battery cable....corrosion up to 8" away from the battery has been reported on AF.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
1996 Jeep Cherokee won't start JSValentine Cherokee 1 02-03-2011 03:51 AM
95 Jeep Grand Cherokee won't start heffe Cherokee 1 08-21-2005 04:25 PM
99 Jeep Grand Cherokee won't start debbie9339 Grand Cherokee | Grand Cherokee SRT8 2 03-27-2005 04:51 AM
1996 jeep grand cherokee won't start lorenzolarouso Grand Cherokee | Grand Cherokee SRT8 4 03-18-2004 10:44 AM
1994 Jeep Grand Cherokee won't start Dickeesun Grand Cherokee | Grand Cherokee SRT8 2 01-24-2004 10:32 PM
