Old 02-07-2012, 11:42 AM
calla1231 calla1231 is offline
Send a message via AIM to calla1231 Send a message via Yahoo to calla1231
97 escort idle problem
97 escort lx wagon, manual, 173,000 miles
When I stop at a red light or stop sign, it takes 10-15 seconds for the idle to drop down to where it should be, and when I push clutch in to shift gears it doesn't drop down, it stays where it is. No codes are coming up. Ideas? I'm thinking IAC
Old 02-07-2012, 06:42 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 97 escort idle problem
Good thought!
Old 02-07-2012, 06:55 PM
P_A_B's Avatar
P_A_B P_A_B is offline
thats a good place to start!
Old 02-08-2012, 06:42 AM
I tested the IAC and it tested fine. Could it still be that?
Old 02-08-2012, 08:43 AM
Pontiac Guy
Possibly, remove and clean the throttle body and the port where the IAC connects. They can get plugged with carbon and cause idling issues just like a bad IAC.
Old 02-08-2012, 03:45 PM
denisond3 denisond3 is offline
If its not the IAC, it could be a vacuum leak that comes and goes. Have a look at the condition of the hose from the PCV valve up to the rubber elbow on top of the throttle body. This 'elbow' eventually rots from carrying so much oily hot vapor. Too bad no one sells just a new elbow - you have to either buy the entire PCV tube and elbow from the dealer, or jury rig a rubber hose to connect the PCV to the throttle body. Myself, I jury rig.
Maybe another possibility: The Throttle Position Sensor (TPS) is how the computer knows you have taken your foot off the gas and it needs to be controlling the rpm. If the TPS is dirty/worn and isnt sending the 'throttle closed' signal, I can imagine the computer wouldnt know to move the IAC valve.
Old 02-09-2012, 04:10 PM
Got a new IAC, it's still doing the same thing. The elbow and hose all look good. The TPS tested fine.
Old 02-26-2012, 03:32 PM
electro452 electro452 is offline
Mine is doing basically the same thing...it comes and goes.
I replaced my IAC with no change.
I was getting a code saying P1101 which indicates a throttle body or mass flow issue. I cleaned the throttle body out and the Mass air sensor...it seemed to work for a week or so now it's back to high idle intermittently ( 1000 rpm) when I stop.
If you find your issue please post....
Old 02-27-2012, 08:15 AM
Pontiac Guy
Did you remove and clean the throttle body? A build-up of carbon on the throttle body blade can prevent it from closing completely and therefore the engine will idle fast. Not a hard job to do either!
Old 02-27-2012, 05:55 PM
Yes I did. I also cleaned the MAP sensor and cleared the code.
The code hasn't reappeared in few weeks but the idle issue remains.
Maybe I should clean the throttle body again and see if it helps..
97 escort idle problem calla1231 Escort 7 06-20-2010 10:36 AM
P0171 Rough idle uspres2020 Escort 8 04-28-2010 08:06 PM
1995 SL Idle Problem peliknhed LS/LW 1 07-07-2009 07:30 PM
Bad Idle... Must be an idle motor problem ? Trueeclipse Eclipse Problem Diagnosis 0 05-25-2009 05:16 PM
97' escort idle problem...please help american_muscle97 Escort 11 10-03-2005 08:46 PM
