Old 02-07-2012, 09:50 AM
joeysz06 joeysz06 is offline
02 silverado bank 1 to lean code
I have an 02 silverado with a 5.3 engine has 140k. My problem only occurs during cold weather starts. It struggles to stay on has a miss but only during initial start once it's warm it runs fine. Kicks out generic code bank 1 running to lean.
Old 02-08-2012, 03:24 PM
j cAT j cAT is offline
Re: 02 silverado bank 1 to lean code
what are the DTC numbers.
also swap O2 sensors see if the DTC changes or not .
the ECT on the driverside of head next to cyl #1 is a possible cause to the poor cold start/run issue.
just to be safe measure the fuel pressure spec is 53-62 psi. should be 60 psi key on engine off. when the engine starts the pressure wil drop a few PSI. 55psi.
any pressure below 53psi is the fuel pump.
replace fuel filter every 30-40,ooomi keep fuel level above 1/4 tank at all times. if you did not do this the fuel pump will die.
The Following User Says Thank You to j cAT For This Useful Post:
joeysz06 (02-08-2012)
Old 02-08-2012, 05:41 PM
Ok will do I believe it's p171 I'll double check only comes on in cold weather truck is Canadian model
Old 02-08-2012, 07:53 PM
I have p0174 and p0171 codes will post pressure readings shortly
Old 02-09-2012, 10:44 AM
Key on fuel is 45psi and engine on less than 50
Old 02-09-2012, 01:42 PM
ya looks like fuel pump.
Old 02-09-2012, 01:47 PM
ya thanx how come they just dont go out and only on cold starts is it cuz the demand for fuel when its cold is more demanding
Old 02-09-2012, 02:15 PM
with those pressures I am quite surprised it does run. with 50 psi most have severe engine running problems.
possible the pressure guage is off a little . that caN happen if its shocked/dropped.
use a delphi fuel pump. replace the fuel filter. since you have 140,oooplus on it replace the fuel pump relay and clean the fuel tank/fuel pump ground on the frame rail next to the fuel tank driverside..
do not use an airtex fuel pump . these are prone to failure after a few months.
joeysz06 (02-09-2012)
Old 02-09-2012, 02:18 PM
Thanx might as well it's going to be on the ground How often should I adjust the valves
96 Windstar lean code bank 1 and bank 2. Please Help DonTom Windstar 6 05-19-2006 01:21 AM
97 SSE Check Engine Light: Left Bank Lean Code Need Help!!! DaPhattsta Bonneville 6 02-26-2006 01:48 AM
00 expedition bank 1 to lean code cjames Expedition 2 02-15-2006 08:45 PM
system running to lean bank 1 code P0171 e_t_phonehome Windstar 2 03-02-2005 10:41 PM
