Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 02-06-2012, 12:33 PM
4boostin's Avatar
4boostin 4boostin is offline
89 Olds. Head Gasket or Intake Manifold?
My 89 Olds 88 with a 3.8 liter motor has either blown a head gasket or intake manifold gasket. There is antifreeze in only one of the cylinders by the firewall, the drivers side end one. I bought the car 4 years ago with 113K on it. It's never overheated and has 158K on it now. Seems kinda weird that the head gasket would go bad?
Can antifreeze get in the cylinder if it's a blown intake manifold gasket?
If it's the head gasket, can I replace just one side?
It's such a good running car, I hate to junk it.
Old 02-06-2012, 03:20 PM
maxwedge maxwedge is offline
A990 racer
Re: 89 Olds. Head Gasket or Intake Manifold?
More than likely it is the hd gasket as manifold gasket issue were not an issue in those years. I would do both while apart if you are keeping the car.
Old 02-25-2012, 07:03 PM
Jrs3800 Jrs3800 is offline
The intake gaskets on that motor will look like complete garbage... The old 3800's did not have as much trouble with them, but they still can go bad...
Drain the coolant, make sure you get all of the coolant out of that one cylinder and do a compression test.... See what you have... Head gasket failure on any 3800 is extremely rare... I would suspect the intake gaskets first...
Do the compression test to be sure...
Old 02-27-2012, 01:31 PM
4boostin's Avatar
I took the intake manifold off and the gasket is plastic. The rubber seals on the gasket in between the holes and such had deteriorated, and were like mush. I could see where the anti-freeze had been leaking into cylinder 6, cause the intake was really clean compared to the others. Installed new gaskets ($25), changed the oil, topped off the anti freeze and all seems to be well. It was blowing blue smoke for the first 5-10 minutes.....maybe the oil ring was stuck or rusted a little from the anti freeze in the one cylinder. I drove it hard for 5-10 minutes and it stopped blowing blue smoke.
Old 02-27-2012, 01:40 PM
Glad to hear you got it going... The smoke you saw was mostly from the moisture that had built up in the Cat Converter... Should be fine now...
Watch you MPG's tho... Its possible for the contamination to take out the O2 Sensor... If the MPG's start to drop you may need a new one... Steer clear of Bosch and or Standard if that happens...
The Following User Says Thank You to Jrs3800 For This Useful Post:
4boostin (02-27-2012)
99 Windstar 3.8L Replacing Intake Manifold Gaskets dariem Windstar 8 03-21-2015 06:22 PM
Intake Manifold Gasket End Seals bjaymo3 Grand Prix 5 07-30-2010 09:29 AM
Replace Intake Manifold Gasket Stammtra Cougar 4 07-20-2010 01:13 AM
Head gasket/intake manifold gasket blew?!?!?!? ajm786 Eighty Eight 5 06-24-2009 10:42 AM
1987 Toyota 22RE Head, Gasket, Intake Manifold, Slave Cylinder, Waterpump Dewitt88 Parts for Sale 0 03-10-2008 11:09 PM
