Old 02-06-2012, 10:55 AM
jldennis jldennis is offline
97 Sunfire 2.2 won't start after changing spark plug wires
We changed the old spark plug wires and now the thing won't start. What could possibly cause this? It was running before we changed the wires.
Old 02-06-2012, 11:26 AM
tempfixit tempfixit is offline
Re: 97 Sunfire 2.2 won't start after changing spark plug wires
Have you double check to make sure a wire may have been disconnected accidentally. Does it have spark??? What brand of wires and did you remove 1 at a time so there was no mix up in proper location of wires??
Old 02-06-2012, 11:47 AM
Yes, the wires were removed and replaced one at a time to make sure they weren't mixed up. They are duralast wires.
Old 02-06-2012, 11:48 AM
Also when we turn it over it pops through the intake and exhaust but won't fire.
Old 02-06-2012, 01:16 PM
ricebike ricebike is offline
you got a voltmeter to test the resistance of each wire? you're going to test if the wires aren't broken inside ~ continuity test
what else did you changed besides the wires? and was it running before you changed them?
old set still good? if so replace the old ones, one at a time... to rule out if you got bad wires from the box (if you don't have a voltmeter)
then return that set since they carry a lifetime warranty????
Old 02-06-2012, 02:33 PM
Spark plug wires were all that we changed and yes it was running before the wires were changed.
Old 02-06-2012, 07:27 PM
well, either you got a bad set
or
you didn't route them properly
ps: i hated going back there to reach for the ignition coil wire end...
here's a live pic for reference, also make sure those plugs to the ignition coil/module weren't bumped off...
how often change spark plug wires? dderolph Integra 10 05-31-2005 03:18 AM
hyndai elantra 2000 check engine signs after change spark plugs loced Elantra | Avante 4 04-15-2005 08:03 PM
No "umph" after changing spark plugs 89chevman C/K 5 09-19-2004 05:18 PM
Changing Spark Plug Wires zeff789 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 3 11-18-2002 04:17 PM
