Old 02-05-2012, 04:18 PM
bwhntr4168 bwhntr4168 is offline
ok now we have a problem its throwing code#po302??
it says that the #2 plug is misfiring the cause could be ingnition system fault? orspark plug which is ne ? or coil? vacuum leak?injector fault?high or low oil pressure? if your driving at a speed and holding it there you can feel the miss ? if you speed up or take off fast it runs perfect?
Old 02-05-2012, 10:24 PM
Re: ok now we have a problem its throwing code#po302??
checked the spark plug its fine! i tuned this motor up over a week ago with new plugs , wires and dist,button! it seemed fine and then driving down the road today i noticed it start to miss??
Old 02-06-2012, 02:08 PM
i have now checked that wire ! i removed the plug and turned it over im getting spark! to #2 cylinder?
Old 02-06-2012, 09:53 PM
any help??
Old 02-07-2012, 10:23 AM
j cAT j cAT is offline
Originally Posted by bwhntr4168 View Post
any help??
remove the plug and plug wire. inspect the wire for damage on the surface. then using an ohmmeter measure the resistance. should be around 5,oooohms .
replace the spark plug . if it is platinum or irridium do not mess with the gap as you will damage the plug.
you could have a bad injector but do the ignition first.
new plugs / wires do not mean good !
The Following User Says Thank You to j cAT For This Useful Post:
bwhntr4168 (02-07-2012)
Old 02-07-2012, 10:29 AM
when you say do the ignition first? what do i check?
Old 02-07-2012, 07:11 PM
that means the spark generatingconducting devices.
Old 02-07-2012, 09:32 PM
well since the spark plug is good i also checked the fuel pump and its goin up to 75# in the key on position and the bleading down to 15# so i have asked several people and they tell me to put the new spider injection in that i have a bad injector?
Old 02-08-2012, 08:28 AM
at the fuel pump filtercycle the pump see what the pressure is and if it holds pressure.
it does hold pressure then the injector may be bad. swap injector see if the code changes.
I said it before new does not mean good . change/swap plug. what is the plug wire resistance ?
Old 02-08-2012, 08:44 PM
checked the wire and 2 others same reading!!
Old 02-08-2012, 10:03 PM
what is the reading ? swap the spark plug with another see if the miss fire code changes.
then you can swap the injector check the injector wires connections.
Old 02-09-2012, 07:00 AM
changed the plug with another same misfire code!
Old 02-09-2012, 07:03 AM
checked all the connection and the pins to make sure all are good!
Old 02-09-2012, 03:49 PM
heres the downfall!! i just replaced the spider injection and the same thing is goin on?? when i checked the wires with a ohms meter im getting 2.14 and something close to that on the other wires? im ready to call the tow truck!!! cant wait to hear what you think j-cat??
Replaced Head Gaskets and now have Problems sbriar Lumina 5 06-12-2009 10:30 PM
Replaced Head Gaskets and now have Problems sbriar Lumina 0 05-28-2009 10:25 PM
