Old 02-05-2012, 10:13 AM
xDonny xDonny is offline
2000 Grand Prix GT Check Engine Light
I've been getting really bad fuel economy and the engine stalls sometimes (only when i'm on a second trip in a short period of time, like if i go into the store and come out, it'll act up) I've cleaned the MAF and IAC sensors and it hasn't made a difference at all. Is there anything I can do? I'm paying like $60 a week in gas (i'm in Canada btw) and getting around 13 MPG when I should be getting ~21 MPG, any help would be much appreciated, is there anyway to check the engine codes myself?
Old 02-05-2012, 01:51 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 2000 Grand Prix GT Check Engine Light
Welcome to AF!!
The only way to check the codes is with a scanner. You can purchase one for about $60 at many automotive retailers. In the US you can purchase one at Sears. Once you get the code you can look it up or some scanners will tell you. I suspect you have a bad O2 sensor that is causing the issue. It is the sensor in front of the cat. Unfortunately the one on the Grand Prix is located behind the engine next to the firewall. You may be able to get it from underneath it if you can get the car off the ground.
Old 02-05-2012, 01:53 PM
I just went down to Canadian Tire and had it scanned. It's the MAF sensor... I guess it's busted, I'm trying to look for somebody parting out a car with my engine that would have one for cheap, I don't want to pay $150 for a new one.
Old 02-05-2012, 01:58 PM
Pontiac Guy
The MAF sensor usually doesn't cause fuel issues but I guess anything is possible. Usually the MAF sensor causes driveability issues. As for the MAF don't purchase a Cardone sensor as they are often bad as their quality is poor.
Old 02-05-2012, 01:59 PM
Okay thanks, and I was reading somewhere else that if you have a bad MAF depending on how you drive it can decrease fuel economy
Old 02-05-2012, 07:24 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Hi Donny,
what did you use to clean the MAF sensor?
If you take a look at it under a magnifying glass you can sometimes see the build up on it which requires a VERY SLIGHT rubbing with a q-tip soaked in either MAF cleaner or electric contact cleaner. You'll see the difference instantly.
If it still doesn't works you might want to go ahead and clean it with a stronger solvent like carb cleaner. It's a "dangerous" movement but if it's damaged already it wouldn't hurt.
MAKE sure the problem is the sensor and NOT the wiring it would suck to replace it and not being the problem. Another possibility could be a bad battery low on charge.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
2002 grand prix check engine light BIGPETEG24 Grand Prix 1 11-09-2007 12:31 PM
2000 grand prix service engine soon light crazyduetoiowa Grand Prix 10 10-31-2007 11:42 PM
2000 Pontiac Grand Prix check engine light on P0410 DTC aaronab1 Grand Prix 2 06-05-2007 06:02 PM
1995 Grand Prix Check Engine Light EGR Solenoid Valve NightTime Grand Prix 1 06-19-2005 05:18 PM
'99 Grand Prix - Check Engine & Shaking On Start-up josiahpr83 Grand Prix 3 11-21-2004 11:03 PM
