Old 02-03-2012, 11:36 PM
chevy69man07 chevy69man07 is offline
1996 silverado z71 4x4 overdrive doesn't work
I have a 1996 silverado z71 4x4 overdrive doesn't work even at 55 or 60 mph. wondering what it could be.
Old 02-05-2012, 09:06 AM
j cAT j cAT is offline
Re: 1996 silverado z71 4x4 overdrive doesn't work
this is a very common condition with high mileage vehicles using dexron III. what occurs is the valves are worn causing the pressure to drop. this then will cause the loss of the 3/4 od to operate.
bring to a transmission shop to verify and if you do this soon you may save the transmission from more damage.
make sure they install dexron VI only. do not use any fluid called dexron III or what ever they think is correct.
torque converter should be flushed out.
1999 Silverado Z71 4X4 Tranny kikkup Silverado 3 09-01-2009 07:33 PM
1999 Silverado Z71 4X4 Tranny Cooler stick64 Silverado 2 08-31-2009 04:32 PM
1996 Silverado Z71 4x4 Problems 93mx6lsv6 C/K 5 06-16-2007 08:43 AM
Please Help, Overdrive Doesn't Work Anymore!! UMREX Camry/Camry Hybrid/Vista 3 07-28-2004 06:25 PM
!999 Silverado Z71 4x4 antilock brakes Anran C/K 2 09-28-2003 09:50 AM
