Old 02-02-2012, 10:22 AM
Wags391 Wags391 is offline
10-year Owner
Time to replace the A/C, slightly DIY
I now live in Florida and my A/C does not work. The heated months are coming quick!
I have a 1992 Chevy S10 Blazer 4x4, 4.3L TBI.
I need to make sure I'm ordering all the parts I need to do an A/C swap. I won't be replacing the condenser or evaporator core, but the compressor, accumulator, and orifice tube. Of course, this means I need to get things flushed and I also will get a new o-ring kit.
Here's my plan. Tell me if I should can't it:
Drain what's left of the coolant.
Disconnect the hose from the compressor.
Remove compressor, accumulator, and orifice tube.
Install new compressor and accumulator but do not hook up.
Take to a shop to flush, install orifice tube, connect lines and fill the system with coolant.
Check for leaks.
How does this sound??
I would try doing it all my self, but I don't have a compressor to do the flush with.
What do you think?
Old 02-02-2012, 06:42 PM
DeltaP DeltaP is offline
Re: Time to replace the A/C, slightly DIY
First of all why did the system quit...have you identified the leak? Are you planning to make the switch from R12 to R134? Then if theres any refrigerant left in the system it needs to be recovered by law and not dumped into the atmosphere.
Old 02-02-2012, 11:04 PM
10-year Owner
I had the system checked, and the compressor is not working like it should anymore. After all, it is the original 92 part. It's already been retrofitted, but I think most of the refrigerant has leaked out. I'm aware of the laws regarding this. I didn't plan to just pull the schrader and let it go.
The system is in need of an overall and I figured with a dying compressor, this is the time to do it.
Any advice on getting it done?
3rd time replacing the Blower Motor Relay waterkeeper03 Impala | Impala SS 7 11-27-2010 12:41 PM
'03 Cavalier with slight ticking (Lifter? Timing? Tensioner?) Bailesie Cavalier Problem Diagnosis 1 07-05-2009 10:35 PM
Having a very hard time replacing the EVO sensor - need suggestions! pnut333 C/K 1 03-13-2009 08:30 PM
Time to replace the shocks in my 1968 Camaro, need suggestions on replacements. ST31 Camaro Discussions 0 12-22-2005 03:20 PM
Having to replace the rack and pinion for the Second time grayls LS | MKZ 1 12-12-2005 02:18 PM
