Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 06-02-2003, 12:58 PM
Kenma Kenma is offline
Wink air filter affect brake?
Hi guys,
I would like to ask if replacement of a clean and brand new filter will affect the brake pressure. Actually, after I replace the old dirty filter with a brand new high flow filter. The brake become a bit soft when step on it compared to a harder brake feeling with the old dirty feeling. There should be no big difference to the braking distance I guess.
Any idea of this?
Old 06-03-2003, 04:47 PM
Cy@tirerack Cy@tirerack is offline
There is no connection between air filter and brake system.
Old 06-05-2003, 03:38 PM
ChaosStarter ChaosStarter is offline
Send a message via AIM to ChaosStarter
1999 Pontiac Grand Prix GTP (2dr)
"Gold" Package
~drop in K&N
~3.4" pulley
~drilled 180º T-Stat
~Casper's cooling fan switch
~U-bend/Resonator removed
Best 1/4: 13.58 @ 100.17 10/25/03
Best 60': 2.07 (stock RS-A's at 30psi)
Best Dyno: 5/3/03
197.4fwhp/262.4fwtq
Coming Soon....
turbo!!
Old 06-21-2003, 04:23 AM
lucyseabug lucyseabug is offline
Red face There could be...
The vacuum creeps up as the filter clogs, raising vacuum boost pressure for the vacuum assisted brake booster whick could tend to cause you to have to press a little harder on the brake to get the same response. The K&N style filter will lower average vacuum in the manifold and decrease brake boost pressure.
I like the old reliable filters because they trap all the dirt before it becomes sandpaper to my cylinder walls.
Old 06-22-2003, 01:01 PM
Thanks lucyseabug, I've posted the same question to several forum, so far, only you reponse with a more logical answer.
After I run for a few days, the dirt build up on the air filter. The brake feeling become the same as before.
Old 06-22-2003, 01:04 PM
btw, I replaced with a brand new K/N filter....
