Go Back   Automotive Forums Car Chat > Geo > Storm
Old 02-01-2012, 07:57 PM
bearcat329 bearcat329 is offline
Angry no spark?
I have a 91 Geo Storm and I am getting no spark. I just replaced the coil pack( has power to the coil ), ignition module, distributor cap,ECM and pick up coil. I have checked all grounds and all fuses and am still not getting any spark. Can anyone give me any advice on what the problem could be??
thanks
Rick
Old 02-02-2012, 01:43 PM
Re: no spark?
well......I guess a broken timing belt can cause all of the above....now to tear it down and see how much damage was done....maybe it's minamal? can always hopee, th engine has less then 80k on it
The Following User Says Thank You to bearcat329 For This Useful Post:
ricebike (02-03-2012)
Old 02-03-2012, 09:57 AM
ricebike ricebike is offline
Re: no spark?
non-interference engine; you got lucky!
it needs to be replaced every 60,000 miles. If it snapped, no worries, the isuzu engines are non-interference so no damage to the head/valves/pistons will take place
just time it correctly, check seals, possibly time to change out the water pump as well if it was original...
Old 02-04-2012, 02:37 AM
Re: no spark?
the geo/chevy dealer told me otherwise! lol, leak checked the valves, held water in the cylinder head for over 20 minutes, guess the valves are water tight!, ordered the gasket set and new timing belt, saved 65$ going thru rockauto.com! now to reassemble it......
Old 02-04-2012, 02:44 AM
Re: no spark?
wow that sucks that the stealership tried to get money out of you; but then even RockAuto's site says it's interference as well
gonna change out the water pump along with it?
ps: how do you know which kit you need?
there's # 169 vs # 177 (guessing the number of "teeth" on the belt??? or belt length)
also noted on eBay at least that the 177 is for the GSi but they both have the same displacement engine <shrugs>
Old 02-06-2012, 07:10 PM
Re: no spark?
the GSI is the double overhead cam version, so a longer timing belt is needed, as far as the "kit" just looked up the gaskets that i needed and ordered them separately. have to see if my son has the extra$$ for the water pump...
the dealership only provided the info I asked for, didn't try to get me in for the repairs, must of been a busy week for them....lol
Old 07-17-2012, 03:39 AM
Jonny Roden Jonny Roden is offline
Re: no spark?
I have a 1993 Storm and I had the same problem with no Spark. I replaced the plugs, plug wires, cap, rotor,and the coil and still didn't have any spark if you have done all that I would say that it is the whole distributor itself, If it is super rusted im sure this is your problem. My mechanic told me that they are supposed to have a gap on them somewhere and if that gap rusts shut they will not work.Anyways $300 and a new distributor that solved the spark issue on my 93 geo storm. This is very simple to replace it took me about 5 minutes All you have to do is pull the cap off then I think it is two more bolts to take the distributor off. also it will need a brand new cap for it because the old one wont fit right if it has been shoved on ur old rusty distributor,
no spark no spark NO SPARK!!!!!!!!!! javatrooper Cherokee 8 08-17-2013 11:02 AM
Spark, Fuel, But not fuel on spark plug? MoonChld454 Cutlass Series 5 05-02-2004 03:59 PM
No Spark at the Coil Pack/no spark to the plug wires crosscypher Off-Topic 13 02-04-2004 06:01 PM
Spark Plugs + Spark Plug wires ricodemus Engineering/ Technical 4 02-27-2002 12:23 PM
