Go Back   Automotive Forums Car Chat > Mazda > 323/Protegé/Familia/Etude/Allegro
Old 02-01-2012, 05:17 PM
Coastie John Coastie John is offline
2002 Protege Overdrive Light
Greetings All,
A couple of days ago we had a cold front come thru and it was in the single digits outside. I noticed the O/D Light was on. Pressing the button wouldn't turn it off. After I got to my destination, let it sit for 2 hours and got back in, the light was off. Now the O/D doesn't work as advertised. Pressing the button does not take off the O/D like it should. No light at all. I starting the troubleshooting phase now. So....does the O/D light come on when starting as part of the momentary test like all the other engine lights? I checked the daughter's 07 Cellica, the 2000 Windstar, the 2003 F-150 and those O/D lights don't come on when starting either. I'll assume the bulb is good. My other thought is a sticky or bad O/D switch on the shifter. Thoughts??
Old 02-04-2012, 04:23 PM
Re: 2002 Protege Overdrive Light
Update.....here's the deal should someone else have to do this. It's pretty easy with the basic tools.
I found the 2 wires to the back of the OD switch broke off. I pulled the handle off, resoldered and heatshrinked two new 4" wires back on and fed it thru the handle and the switch hole. Make sure you use similar size, flexible wire. I used multistrand wire. Reinstall the handle but don't screw it in just yet (You will need to push the handle shifter button in, then slide the handle down). Cut off the excess wire and leave approx 1" to 1-1/4" of wire exposed from the switch hole. Put some solder on the wire ends and switch terminals. Go easy on the switch with the heat. Once done, now solder the switch back on remembering to....be easy with the heat! Ops check the switch to make sure that was indeed the problem and the OD light goes on/off. Once soldered back on, GENTLY pull the handle back off until the wire starts to pull the switch back into the hole....help feed it in and go SLOW. Once there, the switch will easily seat back into the hole. Gently push the handle back on. Ops check the switch one more time. If good, screw the handle in.....put the tools up and go get a cool one.
Old 03-05-2012, 08:45 AM
Mx5guy Mx5guy is offline
Send a message via AIM to Mx5guy Send a message via Yahoo to Mx5guy
Glad to know u got it all figured out, hoping that you isolated the connections well to avoid shorts and accidental grounding, the last step should have been test drive to ensure proper operation then a cold one.
2002 Express dome light issue jtram2 Express | G Van 2 07-23-2010 07:57 AM
2002 Z71 Front Lights Electrical Issu JoeALVES Tahoe 1 03-18-2010 08:00 AM
Flashing engine light, no power 2002 protege Slo Ed 323/Protegé/Familia/Etude/Allegro 4 01-22-2008 01:28 PM
2002 Protege Cruise Control light? The Black Pearl 323/Protegé/Familia/Etude/Allegro 2 12-03-2007 03:29 AM
2002 Protege Overdrive Problems alpajack 323/Protegé/Familia/Etude/Allegro 5 08-02-2007 05:32 AM
