Old 02-01-2012, 08:56 AM
bwhntr4168 bwhntr4168 is offline
4.3 x motor (throttle body) wont run?
its a 97 4.3 4x4 ext cab and ive tuned it up, and if you take the breather off it will stall? does anyone know what causes this?
Old 02-01-2012, 11:35 AM
j cAT j cAT is offline
Re: 4.3 x motor (throttle body) wont run?
what is the breather ? explain ?
crankcase has no breather .
Old 02-01-2012, 12:04 PM
the PCV has a hose/plastic tube to it from the tb base. removal of that tube or damage to it WILL cause the engine to stall.
replace the PCV every 30,ooomi and make sure this works correctly as this can cause idle issues and crankcase gaskets to leak.
Old 02-01-2012, 11:17 PM
its when you take the air breather off? i wanted to clean it with a cleaner and it stalls?
Old 02-02-2012, 08:54 AM
do you have throttle body injection or fuel injection.
if you have fuel injection you cannot remove the air ducting to the throttle body with the engine running .
with the engine off only use throttle body cleaner and DO NOT USE CARB CLEANER. use a toothbrush when cold to loosen the carbon deposits and make sure you wait until restarting as this will flood the engine .
if you have throttle body injection basicly a carb with two injectors be very care full not to damage the injector wires/connections and also no carb cleaner. also clean this when cold and engine off.
air breather is the air filter box ?
Old 02-02-2012, 10:08 AM
very well put thank you very much!!
90 century 3.3 wont run need help kylej Century 5 08-05-2010 09:38 PM
1995 4.3 TBI Throttle sticking rknorr Problem Diagnosis 2 12-02-2009 10:01 AM
96 4.3 l throttle problem Osmax Problem Diagnosis 8 10-29-2007 07:48 PM
92-95 4.3 vortec vacuum line placement--runs then hesitates at throttle up- offroadjoe1012 S-10 1 03-08-2005 01:43 AM
Help Identify This 4.3 Motor wrenchtech S-10 6 01-10-2004 02:41 PM
