Old 01-30-2012, 07:03 PM
colonelcobb colonelcobb is offline
New Mystery
Hi All ! (again)
Thanks again to 12Ounce for his latest suggestion for my 2000 Ford Windstar.
I purchased another relay to replace the #304 position relay. THERE WAS NO RELAY IT THAT POSITION !
I'll explain; About 1-1/2 years ago, my ignition key began to act up. It would intermittently activate the starter, until it quite working altogether.
I got my Windstar towed to a local shop. Since it needed a complete re-build of the steering column (expensive) and couldn't afford it, a mechanic agreed to take a short-cut.
He installed a push-button switch near the headlight switch, and it worked just fine. Although it would start the engine in any gear or not, I was satisfied.
Today, when I re-opened the fuse box to replace the relay in the #304 position, all I found was an empty socket with a jumper wire with a spade fitting plugged into the most forward slot.
This relay is supposed to be also the relay for my fuel injectors. My question is: How did my injectors work for the past 1-1/2 years without it????
Can I leave the jumper wire and still plug the relay into the slots? (it will fit)
Is there anything else I need to check to see why my injectors are not getting electrical current?
Any help would be greatly appreciated !
Boycott Shampoo! KNOW YOUR RIGHTS! Demand REAL poo!
Old 01-31-2012, 08:11 AM
Re: New Mystery
Since no one has answered so far, I'll ask another question. Could my Power Control Module be fried? If so, can I take one off another 2000 Windstar and simply plug the new one in?
Old 01-31-2012, 08:30 AM
12Ounce 12Ounce is offline
Re: New Mystery
I can't answer as to how the injectors have been working in the past for you...it may be rather straightforward, there was a jumper instead of relay contacts.... and you (usually) got away with it.
I would prefer a relay, instead of jumpers, in the 304 position. Remove the jumper. As I believe there is an advantage in having that slight time-delay as the various relays "make". It turns out that both relay #304 and relay #207 are in a series circuit that feeds the fuel pump. So they take a bit of a beating. The contacts wear and burn over time. I have had to replace both of these relays several times on my 330k mile '99 ... and have learned to keep a spare pair on board.
DO NOT CONSIDER replacing the PCM. It is very robust. If you replace the PCM, you will likely either: (1) end up at the dealership for a very expensive PCM/instrument-panel/ignition-key synchronizing with proprietary service equipment, or (2), sending your vehicle to recycle.
The Following User Says Thank You to 12Ounce For This Useful Post:
colonelcobb (01-31-2012)
Old 01-31-2012, 08:37 AM
Re: New Mystery
I'm sure you have done it by now .... but make sure there are no missing relays or fuses in the other positions.
Old 01-31-2012, 09:19 AM
Re: New Mystery
Thanks again 12Ounce, I WAS going to try replacing the PCM, but after reading your post, I won't.
Since my ignition key will NOT engage the starter, could I plug the #304 relay in, while leaving the jumper in place, to use the starter button?
Also, I am NOT getting electrical current to the fuel injectors. The circuit has gone dead. I don't know what else to look for if not the PCM. (but I haven't yet tried the jumper/relay combo yet either)
Old 01-31-2012, 09:57 AM
Re: New Mystery
The relay should totally/correctly do whatever the jumper was doing. Remove the jumper. Install the relay ... and give us an update on symptoms.
In the meantime, I'm gonna try to find my circuit diagram book for the Windstar to see what drives the injectors. Stay tuned!
Old 01-31-2012, 10:00 AM
Re: New Mystery
Can you describe/identify what conductors the Gerry-rigged pushbutton is attached too?
Old 01-31-2012, 10:59 AM
Re: New Mystery
BTW ...please do not start another string until we get this thing all sorted out! Its getting a bit difficult to stitch the story together!
Now I am concerned about the short cut the guy took .... and what was wrong with the "steering column" to begin with? I suspect the ignition switch was bad. They do fail with wear. Operated by a link-rod attached to the key tumbler. About the size of a cigarette pack .... down inside the column cover about 24" below the strg wheel. $50 IIRC.
So now what has he jumpered out? There may also be something inside the column cover down at the switch. Wish you would look.
This is what I hate about short-cuts and re-engineering. It usually is not well documented. Gets one out of the woods .... for awhile. Then no one knows whats what!
Enough of that. It will take me a few hours to put my hands on my Winny elect book. Could you also give us a fresh accounting of its final run hours ... how exactly did it seem to fail? Do you have any idea what the codes are?
No new strings ... please!
Old 02-01-2012, 11:37 AM
Re: New Mystery
Since this was the most recent string you started .... I'm gonna bump it back on top.
I now have my elect diagrams. The injectors are fed directly from the PCM .... with inputs from the crank and cam position sensors, the ECT, the throttle pos sensor, etc , etc.
Do you have any new information for us? .... any answers to above questions? ... what are current sysmptoms?
colonelcobb (02-01-2012)
Old 02-01-2012, 04:27 PM
Re: New Mystery
I'll stay with this posting to avoid any further confusion, sorry 'bout that !
The following is a copy from my latest reply to a different thread (Cringe ! )
Thanks again for everyone's help, and, no new thread ! LOL
OK, first, I had the #302 and the #304 relay's backwards (I was reading the inside cover diagram backwards).
I now have a new #304 relay installed. The #302 (start interrupt) is the one that is missing and where the jumper wire is located to crank the engine from the dash mounted push-button.
I disconnected one fuel injector plug and attached my multi-meter, turned the key to the "on" position, and cranked the engine. The test meter showed voltage activity. I couldn't get an exact voltage reading as the meter would not respond fast enough to read the brief pluse.
I have purged all the air out of the line with the fuel-line purge valve and have fuel.
The engine cranks and runs with gasoline injected directly into the intake manifold.
The engine will not continue running nor start, without an initial prime.
I've checked for any "massive" vacuum leaks and found none.
What could I be overlooking? Please help.
Old 02-01-2012, 09:08 PM
Re: New Mystery
OK, it appears that after I admitted that I got the #302 & #304 relays backwards, I guess everyone figures that since I so DUMB, that my question doesn't even warrent an answer!
Well ! I've got news for you guys ! I'M NOT as dumb as you think! I CAN "walk-and-chew-gum" at the same time! How do I know?
I've done it on several occasions!
Old 02-02-2012, 11:33 AM
Re: New Mystery
Originally Posted by colonelcobb View Post
......The engine cranks and runs with gasoline injected directly into the intake manifold.......
Great! We/you are making progress!
It sounds like the initial cranking (without the raw fuel in the intake) is not totally effective ... (1)(2)so is the fuel insufficient, or poorly timed?.... or, (3) is the cranking not recognized?. .... or, (4) something else, unknown?
(1) Did you ever clean the inlet screens of the injectors?
(2) How about the cam position sensor synchronizer? Is it timed properly? Does it need a few drops of motor oil down the shaft for lubricant?
(3) We can be pretty sure the PCM is OK, since it will run ... but how about the crank and cam sensors? Are they flakely?
(4) Is there any way you can drive it somewhere and have the code(s) read?
Old 02-02-2012, 03:04 PM
Re: New Mystery
Thanks 12Ounce, at least someone thinks I'm smarter than a potato!
1) What inlet screens?
2) What cam position sensor? And the oil goes where?
3) Crank and cam sensors,...........flakey? As in crumblling apart?
4) I could hire a midget to sit on a fender, (with the hood open) to pour gasoline into a funnel that drains into the intake, while he gives me directlions where to turn and what not to hit, as I drive over to the local Autozone!
Old 02-02-2012, 04:32 PM
tempfixit tempfixit is offline
Re: New Mystery
Have you thought about seing if autozone has a code reader in their rent a tool program??? Pay a deposit and read the code take it back and get your deposit refunded.
Old 02-02-2012, 04:38 PM
Re: New Mystery
tempfixit
I'll try that route..........thanks!
Taurus Dies Mysteriously the100thballoon Taurus | Taurus Wagon 19 11-04-2010 10:14 PM
(eBook) Buying New and Used Car Tips schumi_reloaded Car Buying Q&A 2 06-05-2009 11:18 AM
new aftermarket parts for sale tommy67 Parts for Sale 1 04-24-2009 01:34 PM
New Feature '97ventureowner Cars/Parts for Sale/Exchange 0 02-19-2009 10:21 PM
New Mystery 2000Zu Rodeo | Passport | MU 6 01-16-2008 02:16 PM
