Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 01-30-2012, 12:17 PM
VentureBoy VentureBoy is offline
Venture front end vibration?
Hi all. I have a Venture with a steadily-worsening vibration problem which is always worse at the front passenger side. The vibration is not the growly rumble I remember from the bad bearings I replaced 3 years ago. It's more like the thudding feel of an out-of-balance tire, but the tires are relatively new and have been rotated and balanced since purchase and since I noticed the problem. The vibration shows mainly from 45-55 mph, but not if coasting. It's only when the engine is under load that I feel it. It occurs when the gear select is in D or 3. At any other speed it is not as bad, but if I get on the gas, the vibration becomes worse. Revving the engine in park or neutral reveals no abnormal vibration.
I jacked up the van and rotated the tires again and checked for any play in the bearings or loose mounting bolts - nothing obvious there. I did notice on the passenger side of the engine, around the inboard CV joint, a spray of thick axle/moly grease, like one would find inside a CV boot, as if the boot has a small hole in it, but the CV joint does not grind or make any typical noise on sharp turn.
My list of guesses include: motor mounts, tranny mounts, bad bearing/hub, bad half shaft/CV joint, tranny going bad, bad bearing in engine.
History/details:
2004 Venture LS long wheelbase. 160,000 miles. Goodyear Viva 2 tires. Front bearings have been replaced as a set once, driver side again since then, when the ABS sensor went bad. Sometimes when I put it into drive and turn sharply to the left, traction control turns on momentarily. The tranny has begun to slip and grab on a coast-to-stop followed by sudden acceleration.
Old 01-30-2012, 12:45 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Venture front end vibration?
I think you may have a couple of things...worn axle shaft(s) causing the vibration and worn eng/trans mounts transmitting the vibration. The mount on the R/F, by the oil pan, crank pully, is bad for collapsing and causing noises.
Old 01-30-2012, 01:09 PM
Is that motor mount the one that looks like this?
Old 01-30-2012, 04:45 PM
gmtech1's Avatar
yes
The Following User Says Thank You to gmtech1 For This Useful Post:
VentureBoy (01-31-2012)
Old 01-31-2012, 11:48 AM
yes
Thanks for the input. I will likely start with the CV shaft and see how much improvement I see before considering the mount.
Venture front end noisy toni1595 Venture 2 10-23-2008 03:10 PM
Front End Vibration OTOOL Windstar 1 08-28-2005 08:09 AM
Venture Front end alignment wpowell Venture 2 05-07-2004 11:18 AM
Front End Vibrations ppn7574 General Discussion 2 11-23-2002 09:23 AM
Front End Vibration-Drivetrain? jfhmel 7 Series 2 05-28-2002 04:43 PM
