Old 01-29-2012, 12:59 PM
greasyhog greasyhog is offline
AF Premium User
Intermittent Secuirty Light
So every once in a great while the security light comes on after I start the car. Codes are B2958 data open/short to battery security system sensor data circuit high and B2961 key in ignition circuit malfunction. Car drives and starts fine (except for an extended crank sometimes). Last time I had the B2958 code the dealership had me replace the BCM then the lock cylinder and they also did some wiring diagnostics. I'm hoping I won't need to do that again. Does this look like the lock cylinder may need replaced again?
03 intermittent starting problem tmarsh CR-V 1 12-10-2011 05:12 PM
Fixed Intermittent ABS light and Brake light! pb1998 Windstar 0 03-06-2007 01:00 PM
Intermittent Battery Light pfnjr '88 - '91 Civic | CRX | Wagon | Shuttlee 3 09-07-2004 11:58 AM
Intermittent Signal Light/Hazard Problem bashawstar Grand AM 4 07-14-2004 07:49 PM
intermittent brake light error message Rook 3 Series 8 08-07-2002 10:20 AM
