2000 ford windstar airbag code 36
i have a 2000 ford windstar with a airbag code 36, can somebody point me in the right direction, thanks.
Re: 2000 ford windstar airbag code 36
Do you have side air bags??
TEST T: LEFT-SIDE AIR BAG CIRCUIT SHORT TO GROUND (DTC B1993) Description RCM checks left-side air bag module circuit for shorts to ground by monitoring voltage at RCM harness connector C232, terminals No. 2 (White/Light Blue wire) and No. 3 (Black/Light Blue wire). If RCM detects resistance less than 1000 ohms at either terminal, it will store DTC B1993 in memory and flash Code 36 on AIR BAG warning light. Possible Causes A left-side air bag circuit short to ground could be caused by a short to ground on White/Light Blue wire 1(circuit 1257), a short to ground on Black/Light Blue wire (circuit 1258) or a short to ground in left-side air bag module. TEST V: LEFT-SIDE AIR BAG CIRCUIT SHORT TO BATTERY OR IGNITION (DTC B1992) Description RCM checks left-side air bag module circuit for shorts to battery or ignition by monitoring voltage at RCM harness connector C232, terminals No. 2 (White/Light Blue wire) and No. 3 (Black/Light Blue wire). If RCM detects battery or ignition voltage, it will store DTC B1992 in memory and flash Code 36 on AIR BAG warning light. Possible Causes A left-side air bag circuit short to battery or ignition voltage could be caused by a short to battery or ignition (circuit 1258) or a short to battery or ignition voltage in left-side air bag module.voltage on White/Light Blue wire (circuit 1257), a short to battery or ignition voltage on Black/Light Blue wire TEST X: LEFT-SIDE AIR BAG CIRCUIT RESISTANCE HIGH (DTC B1994) 2000 Ford Windstar 2000 ACCESSORIES/SAFETY EQUIPMENT Ford Motor Co. - Air Bag Restraint Systems Description RCM monitors resistance of left-side air bag module circuit loop and air bag igniter at RCM connector C232 terminals No. 2 (White/Light Blue wire) and No. 3 (Black/Light Blue wire). If RCM detects resistance more than 3.6 ohms, it will store DTC B1994 in memory and flash Code 36 on AIR BAG warning light. Possible Causes Left-side air bag circuit high resistance could be caused by damaged White/Light Blue wire (circuit 1257), damaged Black/Light Blue wire (circuit 1258), damaged left-side air bag module or disconnected left-side air bag module. 1. Check for hard or intermittent DTC Ensure ignition is off. Connect scan tool to DLC. See USING SCAN TOOL under DIAGNOSTICS. Turn ignition switch to RUN position. Retrieve and record any continuous DTCs. See RETRIEVING FAULT CODES under DIAGNOSTICS. Perform on-demand self-test. See ON-DEMAND SELFTEST under DIAGNOSTICS. If DTC B1994 was retrieved during on-demand self-test, fault is hard. Go to next step. If DTC B1994 was not retrieved, fault is intermittent. Go to step 5 . 2. Check left-side air bag module Turn ignition off. Disable air bag system. See DISABLING SYSTEM under DISABLING & ACTIVATING AIR BAG SYSTEM. Turn ignition switch to RUN position. Perform on-demand self-test. If DTC B1994 is retrieved, go to next step. If DTC B1994 is not retrieved, replace left-side air bag module. See SIDE AIR BAG MODULE under REMOVAL & INSTALLATION. 3. Check left-side air bag circuits Turn ignition off. Access and disconnect RCM connector C232. See RESTRAINTS CONTROL MODULE under REMOVAL & INSTALLATION. DO NOT separate or remove shorting bars from connector C232. Remove air bag simulator from under-seat connector. Zero ohmmeter. Measure resistance between White/Light Blue and Black/Light Blue wires on RCM side of left-side air bag module under-seat harness connector. If resistance is more than one ohm, repair open in appropriate wire and go to step 6 . See WIRING DIAGRAMS .If resistance is less than one ohm, go to next step. 4. Check left-side air bag wiring Inspect all crimps, terminals, wires and connectors in circuit No. 1257 (White/Light Blue wire) between left-side air bag module under-seat harness connector and RCM connector C232, terminal No. 2. Inspect all crimps, terminals, wires and connectors in circuit No. 1258 (Black/Light Blue wire) between left-side NOTE: New RCM is programmed from the factory for vehicles with side air bags. If new 2000RCM has been installed in vehicle without side air bags, RCM will flash Code 36 on AIR BAG warning light. NOTE: Before proceeding, See AIR BAG SAFETY PRECAUTIONS . TEST Z: LEFT-SIDE AIR BAG CIRCUIT RESISTANCE LOW (DTC B1995) Description RCM monitors resistance of left-side air bag module circuit loop and air bag igniter at RCM connector C232 terminals No. 2 (White/Light Blue wire) and No. 3 (Black/Light Blue wire). If RCM detects resistance less than 1.4 ohms, it will store DTC B1995 in memory and flash Code 36 on AIR BAG warning light. Possible Causes NOTE: Before proceeding, See AIR BAG SAFETY PRECAUTIONS . 2000 Ford Windstar 2000 ACCESSORIES/SAFETY EQUIPMENT Ford Motor Co. - Air Bag Restraint Systems Left-side air bag circuit low resistance could be caused by damaged White/Light Blue wire (circuit 1257), moduledamaged Black/Light Blue wire (circuit 1258), damaged left-side air bag module or incorrect left-side air bag |
Had the same code when I bought my 2000, connectors under seat were neatly plugged, but no continuity. Followed wires to fuse box where I noticed that not only was fuse missing, but the socket only had ground connector pin. Turns out previous owner had retrofitted van with leather power seats taken from an SEL ( when I first bought the van I had thought it odd to have those seats in an LX) but had neglected to run power for the side airbags which are contained in those seats. Guess he wanted to avoid creating yet another potential source of electrical issues.
2000 Dodge Dakota SLT 4x4 5.9L V8 - Brutal 2008 F150 FX4 5.4L V8 - Wintermobile 2000 Windstar SE 3.8L V6 - Beast of burden 1995 BMW 540i 4.0L V8 - Weirdest car ever owned |
