Old 01-26-2012, 05:18 PM
rw1644h rw1644h is offline
2000 Grand Caravan 3.3 Overheating
My GC is overheating. Started as occassionally but now increasing in frequency. I find it will being to overheat after driving on the interstate for half hour or so but I can "calm" it back down but turning on the heat.
I've replaced the following:
1. coolant (no drips or leaks nor am I losing coolant over time)
2. thermostat (twice)
3. temperature sensor
4. serpentine belt and tensioner
5. radiator (last summer)
6. water pump (last winter)
I notice the fans run more often than they should. For example, after a 10 minute ride to work in the morning,. I notice the fans are running as I pull into my parking space.
Old 01-26-2012, 06:09 PM
jamesslcx jamesslcx is offline
Re: 2000 Grand Caravan 3.3 Overheating
rw, how about the radiator cap? when started cold how long does it take to overheat? Checked airflow through radiator, making sure nothing is blocking airflow?
Old 01-27-2012, 12:03 AM
I forgot to mention that I had also replaced the radiator cap just recently. There doesn't appear to be any airflow restriction.
Old 01-27-2012, 09:58 AM
rw1644h, the only other thing I can think of at the moment, have you did a backflush of the cooling system? Any other problems with the van like check engine light on?
Old 01-27-2012, 10:59 AM
No CEL's. I connected a scan tool; no faults. Regarding backflush, with the recent work I've done, I've did a prestone flush solution and drained. Also, after that, I've drained the coolant a few times to perform other work. Once by disconnecting hose at water pump. It drained like a torrent. I never power flushed though, if that's what you mean...
Old 01-27-2012, 11:20 AM
rw, kind of unlikely but it does happen is that deposits or sediment settles in the waterjacket of the block and slows or stops coolant circulation, sometimes you have to buy a kit from the parts house and splice it into the heater hose to flush out the block. You have just about covered everything else, does the engine seem to run as good as it always has?
Old 01-27-2012, 11:29 AM
aleekat aleekat is offline
Are you sure its not the gauge or sending unit?
Old 01-27-2012, 03:42 PM
If the sensor is what you're referring to, I just replaced it. Correct me if I'm wrong but isn't there only one coolant temp sensor? I don't see a second sensor/temp switch listed on the major parts suppliers' websites. The gauge needle is moving in an reasonable fashion but I can't say whether the gauge is mis-indicating.
Old 01-27-2012, 04:35 PM
One coolant temp sensor and probably an engine temp sensor to run the gauge. I'm at a loss, you have covered most everything and the fans seem to be working. Try checking the actual engine temp with an infrared thermometer. Good luck
Old 01-27-2012, 05:28 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
There's one single ECT sensor for the combined gauge and PCM signals. Ask a rad shop what they use as a flush solvent. Did this problem start before all the parts were changed?
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 01-27-2012, 05:55 PM
wire2power wire2power is offline
Check the oil for radiator coolant. to check this all you need to do is pull out the oil dipstick and look for a "milky" film. Kind of looks like Bailey's Irish Cream. That will tell if you have a bad head gasket. There is another way to tell if it is, what you call a radiator check valve, the thermostat. When the car is cool remove the radiator cap, grab the top radiator hose leading to the thermostat housing, and gently squeeze the top radiator hose. If you see air bubbles in the radiator, the thermostat needs to be changed.
I understand you installed the thermostat twice and water pump. I'm going with bad head gasket...Good luck!
Old 02-01-2012, 04:03 PM
The oil is nice and black, not creamy.
I can drive all day with the heater on high.
I did another CO2-in-the-coolant check with a borrowed "Blue Point combustion Leak tester"; came up negative.
I'm wondering if I have coolant flow blockage to the radiator.
The only problem is a schematic. Searches turned up negative. Even the on-line parts suppliers (even the Mopar ones) don't list all the components. Yeah, the standard stuff is there: radiator, WP, T-stat, etc, but nothing on the bypass and heater hose side of things. So, that being said, I'll start by asking questions.
From the water pump, a hose travels along the front bank. and then where...
From the driver side of the block, a flanged pipe turns ninety degrees and towards the firewall.
Question: With the heater NOT on high, starting at the WP, what is coolant flow path?
Old 02-01-2012, 04:23 PM
DeltaP DeltaP is offline
Check the belt and tensioner again. It may be slipping at hiway speeds. If I remember that tensioner has a built in indicator on the casting to show if theres enough tension being applied to the belt. The belt might have oil or dirt on it or be a 1/2 inch too long also the radiator might not have enough flow.
Old 02-01-2012, 05:06 PM
Belt tensioner/belt are fine. I replaced them both 3 weeks ago and the same behavior. I would think if its a lack of flow due to slippage, then "heater-on-high" would not relieve the problem.
Old 02-01-2012, 07:17 PM
Alphabravo Alphabravo is offline
Does it get hot enough to throw the "check guages" light and chime? Or does it just read hotter than normal?
If if just reads hotter than normal, I'm wondering what kind of radiator they sold you. Does it have one row of vanes or two? Cheaper after-market radiators sometimes have less cooling capacity than originals which cause the vehicle to run warmer. Although, they SHOULD keep the car sufficiently cool.
Another possible problem could be some trapped air.
Good luck.
92 Grand Caravan 3.3 Coolant Question Rschrei518 Caravan | Voyager 1 07-19-2008 08:02 AM
2000 Grand Caravan 3.3 Cooling fans spectre09 Caravan | Voyager 6 01-27-2006 06:34 PM
2000 dodge grand caravan stalls..3.8 ltr engine t_pizzo Caravan | Voyager 5 01-02-2006 05:51 PM
Instrument cluster out 2000 grand caravan jwimebb Caravan | Voyager 10 03-13-2004 11:03 PM
Creaking, squeaking 2000 Grand Caravan rykerjenbob Caravan | Voyager 3 01-29-2004 06:53 PM
