Old 01-25-2012, 04:54 PM
Trio3b Trio3b is offline
Send a message via AIM to Trio3b Send a message via Yahoo to Trio3b
'93 PA rear wheel camber
1993 PA with 250,000 miles. Searched forums but just found a thread on how to swap out bearing hub.
I think we changed out rear shocks/struts about 3 yrs ago. Daughter now driving and I notice passenger rear wheel from behind looks like camber out of whack. Sometimes positive sometimes negative. mostly negative. Something is loose.
no play when grabbing wheel at 9 and 3 oclock. There is some ( about 3/8 to 1/2" ) when grabbing wheel at 12 and 6 oclock.
I have heard that rear alignment is possible either w/ shims or bolt adjustment. just not sure. This can't be a be a bearing making NO NOISE can it? Tire wear is mostly inside which means neg camber. I don't see anywhere where the shock/strut clamp bolts have shifted
Any ideas appreciated.
Old 01-25-2012, 08:15 PM
Blue Bowtie's Avatar
Registered Offender
Re: '93 PA rear wheel camber
A bearing with play would allow movement in all axes, not just vertical (12 and 6 o'clock). I'd suspect the lower control arm bushings, lower ball joint, and/or lower mount for the rear strut.
Old 01-26-2012, 08:35 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
You'll need another set of eyes to look underneath while you move the wheel to isolate for sure where the play is. I have seen bearings with play not cause a noise. Could be bearing, bushing, ect...
Old 01-26-2012, 09:38 AM
Tech II Tech II is offline
I agree with Bowtie...not a bearing if it doesn't move at 9/3 position.....
Agree with Gmtech1....jack it up and create movement, and have another set of eyes to see where the movement is coming from.....
Old 01-26-2012, 09:26 PM
Thanks guys. Can't get to it for a few days but will post back and keep posted.
89or90 2600i 4x4 rear wheel bearings B4 roadtrip discretegeek B-Series/Bravo/Bounty/Drifter 0 03-29-2010 08:38 AM
89or90 2600i 4x4 rear wheel bearings B4 roadtrip discretegeek B-Series/Bravo/Bounty/Drifter 0 03-29-2010 08:37 AM
Rear wheel camber after changing struts FRANKENCAMRY Camry/Camry Hybrid/Vista 1 11-16-2006 11:10 PM
rear wheel camber euro91 Lumina 2 08-14-2005 11:36 PM
Rear Wheel Camber Correction??? slyhog-22056 Technical 4 02-14-2005 09:31 PM
