Old 01-24-2012, 07:14 PM
catmama14 catmama14 is offline
97 grand prix gtp supercharger
I have a 97 grand prix gtp sc. 2 wks ago I got a p0141 code. I know it's the bank 1 sensor 2 after the cat. It went away last weekend. Then on Thursday, it stalled on the road and starts right away, but won't stay running. Had it towed home. Cleaned the maf sensor and replaced the fuel filter. The fuel pump sounds fine. Checked the fp relay and fp spd cntrl relay, both seem fine. Does anyone have any idea on what the problem may be? I do have headers with straight pipes and i do have a modified k&n cold air intake. It does start smoother and it idles smoother, but after 10 seconds, it stalls. I started it with the maf engaged and the maf not engaged, there wasn't any difference. help me pls.
Old 01-24-2012, 10:03 PM
Tech II Tech II is offline
Re: 97 grand prix gtp supercharger
Well, spray carb cleaner into the intake and see if it continues to run as long as you spray.....if it does you have a fuel delivery problem......
What a lot of people don't know is, there is a ceramic resistor in the circuit to the fuel pump......don't remember if it was a recall or TSB.......but if that resistor has never been replaced, that could be your problem...it could be cracked.....it is located in the front passenger side wheel well......the tsb/recall relocates a new one to the engine firewall on the passenger side.....if it was a recall, it has run out on time by now..........
There is a brace on the passenger side inthe engine compartment, and a wire loom is attached to it.....that loom goes down into the wheelwell to the resistor.....
The Following User Says Thank You to Tech II For This Useful Post:
catmama14 (01-25-2012)
Old 01-25-2012, 08:02 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Welcome to AF!!
I agree with Tech II about the fuel pump resistor. If they go bad they can leave you sitting beside the road. These resistors are hard to get to but they are not hard to change once you find them.
The Following User Says Thank You to GTP Dad For This Useful Post:
Old 01-25-2012, 11:34 AM
Thanks for the reply. We are getting the resistor today, so I will let you know how it goes.
Old 02-06-2012, 11:32 AM
We replaced the FP Resistor (had to order it from the dealer) and the fuel filter. Now I'm getting codes P0171, P0102 and P0306. It seemed fine when we first started it, but when I revved it, the SES came on and these codes came up. Replaced the MAF sensor and now it sounds like it's not getting enough fuel when idling. Replaced the FP Relay and FP Spd Cntrl Relay. Started it this morning to warm up, when I got in to leave, SES light flashing. Shut it off, waited 5 minutes, started it back up, smoothed out a little, drove 25 miles to work. Seemed fine until I stopped at a light, idling rough. Any ideas on where I go from here? SES not flashing, but still on. It just seems like it's starving for something, and there are so many possibilities that I have no idea on where to even start.
Old 02-06-2012, 08:44 PM
When the CE light flashes, that's a bad misfire.....what did you do about P0306?
Also check for vacuum leaks, check the vac hose to the f/p regulator for fuel and see if the car runs better with the MAF disconnected.....
1998 grand prix GTP 3.8L V6 supercharged, random misfire gtpmaddi Grand Prix 2 04-19-2011 08:16 PM
98 Grand Prix Wont Start, need help ASAP! atdudonis Grand Prix 3 06-17-2010 08:57 AM
2002 Grand Prix GTP Supercharger & Serpentine Drive Belts GT4NE1 Grand Prix 3 08-02-2007 12:32 PM
can a 3.8L grand prix GTP supercharger fit on a 2k 4.3L??? FastTeen C/K 3 11-09-2005 12:41 AM
