Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 01-23-2012, 06:15 PM
Robmoo Robmoo is offline
Brakes stay applied and stabilitrak service light goes on
On my 2006 Envoy I'm having an intermittent problem. First the brakes start to get grabby. Then they don't completely disengage. Then the stabilitrak light and the stabilitrak service light light up. I've tried cleaning the ECBM ground and that didn't solve the issue. All of this started after I changing the serpintine belt and alternator.
This issue is starting to drive me nuts. Any idea what the problem could be?
Old 01-23-2012, 08:35 PM
aleekat aleekat is offline
Re: Brakes stay applied and stabilitrak service light goes on
The times I have had gurgling in the system, trapped air. Had to "burp" the coolant system.
Old 01-24-2012, 04:13 PM
maxwedge maxwedge is offline
A990 racer
Make sure the brake fluid is not contaminated with say p/s fluid,I have see these exact symptoms from this mistake. It would be seperated from the brake fluid and have an oily feel.
Old 01-24-2012, 05:38 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Agree with Max, sounds like fluid contamination. When you pull the master cylinder cap pay attention to the seal under/attatched to the cap. If it's swelled up and soft, thats a sure sign of contamination.
Old 02-05-2012, 09:44 AM
tmenna tmenna is offline
I am having the same issue. I checked my fluid and it is not contaminated and do not have any tripped codes. This is my wifes car and it bothers me that it may happen when she is driving. Any other ideas?
Old 02-06-2012, 03:18 PM
A990 racer
Are you checking for abs codes with an abs function scanner as a regular obd11 scanner will not pick up abs codes.
