Old 01-23-2012, 04:44 PM
Searles Lewis Searles Lewis is offline
Smile Ford windstar 2000 Center Power Door Adjustment
I have a ford windstar 2000. I accidentally broke the rear quarter window while trying to fix a broken roller assembly on it. I replaced the roler assembly, and used wd-40 to clean off the molly I previously used to lube the roller track-the track and prior bracket were bent, and I bent them back. It had been creaking and barely moving, all fixed by WD-40! I had always been told not to use that! Wow, what a relief1
but, the center (it's a 4 door van, center doors are power) doors for the middle bucket seas, the left hand side one I fixed is now overlapping with the replaced rear quarter windows! I have been unable to adjust the half centimeter it needs it stop it from overlapping.
Can I just drill 4 new holes to the right of the current and wrench it in?
The last nut/screw that holds the end of the window seems to have a round joint, so if it is off a little it wil lstil lwork.
will this work?
TIA for the help, and the prior help. I never would have tried Berryman's B-12, nor wd 40 for the roller assembly, ever!
Old 01-26-2012, 08:45 PM
Smile Re: Ford windstar 2000 Center Power Door Adjustment
will this work?
I was able to move the window over, and then now have a problem with the door that the mechanic "fixed" by bending numerous door hanging parts, and now closes perfectly, then backs up.
The window I used a screw, nut and the original parts to just extend out the screw that normal is in the belly-button like metal piece at the end of the window, it works.
Any suggestions for the dumb door not closing all the way all of the time?
Old 01-27-2012, 02:24 AM
Windstartled Windstartled is offline
You mean the door latches, then breaks loose? Could be that it got "fixed" by the mech in such a way that it doesn't latch properly anymore.
2000 Dodge Dakota SLT 4x4 5.9L V8 - Brutal
2008 F150 FX4 5.4L V8 - Wintermobile
2000 Windstar SE 3.8L V6 - Beast of burden
1995 BMW 540i 4.0L V8 - Weirdest car ever owned
2000 Ford Windstar - fuel tank display failure & flahing lights & rear heat Fulcrum Windstar 8 05-28-2011 11:31 AM
2000 Ford Windstar, Not a whole lot of knowledge cshawn Windstar 8 08-14-2010 05:40 PM
2000 Sonoma power steering adjustment??? bigwillie1957 Problem Diagnosis 2 05-11-2009 04:10 PM
I love the Ford Windstar 1999 serge_saati Cars in General 0 05-09-2009 02:51 PM
Ford Windstar 2000 not idling smoothly mlaframboise Windstar 8 12-07-2004 11:39 AM
