Go Back   Automotive Forums .com Car Chat > Isuzu > Rodeo | Passport | MU
Old 01-23-2012, 03:46 PM   #1
NJFrank
Question !996 Passport 3.2 Alternator dying?
Hi.
The voltage slowly drops to 8-9 volts. At which point the radio will shut down then shortly after the entire car. The truck is 16yrs old and does have substantial underbody rust.
I only get a click when trying to restart, but it will start after a rest or jump.
I'm assuming the alternator is the issue ( I have eliminated the battery as the fault).
Just wanted to get others opinions. I just need this thing to survive another 6 months hopefully.
171k miles 3.2 automatic
Thanks
NJFrank is offline   Reply With Quote
Old 01-23-2012, 11:35 PM   #2
amigo-2k
Isuzu Guy
Re: !996 Passport 3.2 Alternator dying?
You might want to check where the battery grounds too (I think it grounds to the engine block).
If you need a cheap alt, buy a used one. Find a local junk yard car-parts.com or ebay.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
amigo-2k is offline   Reply With Quote
Old 01-24-2012, 09:19 PM   #3
ricebike
Frank, sounds like it ~alternator should be charging at ~14.5 Volts
possible worn brushes inside; remove and have it bench tested for free at a local parts store like autozone or advance autoparts
few salvage yards with a lifetime warranty on the part are good alternatives to parts' stores remanufactured alternators
good luck!
ricebike is offline   Reply With Quote
Old 01-25-2012, 02:29 PM   #4
NJFrank
good luck!
Hello fellow jersyite (is that what they call us). i picked up a junkyard alternator and right now it;s not working out too well (but I ca bring it back if need be). PITA though to have to take it back out again.
I'll look into the autozone thing, didn't know they would bench test an alternator. Right now just have to get it done before the weather turns bad.
Thanks
Old 01-25-2012, 04:55 PM   #5
ricebike
Thanks
that is a PITA... take both of them to the local parts store, I dunno if they're near you.
I vaguely remember if Strauss Auto, PepBoys, maybe NAPA still have bench testers at their parts counter (doesn't hurt to look them up / give em a call before venturing out there)
that way if those 2 alternators are tested "good" on the bench, you can start looking at the wiring instead
good luck, fellow Jersean
94 Passport 3.2 ticking/knock ralpht44 Rodeo | Passport | MU 10 04-12-2007 01:24 AM
1995 passport 3.2 no spark 89civDx Rodeo | Passport | MU 0 01-29-2007 09:30 AM
94 Passport 3.2 bad injectors ralpht44 Rodeo | Passport | MU 0 10-10-2006 08:19 AM
94 Passport 3.2 running rough ralpht44 Rodeo | Passport | MU 4 09-14-2006 09:50 PM
99 Honda Passport 3.2 V6 code # P0440 98JGCDMC Rodeo | Passport | MU 1 04-04-2005 11:31 PM
