Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-22-2012, 11:31 AM
phynix21 phynix21 is offline
Rough idle after warm up
1998 eclipse spyder gs
i had to jump start the car and i crossed the positive and negative wires, i know how stupid that was.
had to replace 100amp fuse for alternator
now when i start the car it runs fine until it warms up ( ten minutes or so sitting in the driveway or about a mile of driving around the neighborhood) then the idle goes nuts and the car will kill unless i keep tapping the gas.
any idea which sensor could cause this to happen?
at first i thought it was the fuel pump but after getting it tested i now know thats not the problem.
my guesses are the O2 sensor or the MAF
any ideas from anyone would be great!
Old 01-23-2012, 09:55 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Rough idle after warm up
Do you have a check engine light that comes on when its trying to die? You could have possibly fried the ECU by crossing the terminals.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 01-25-2012, 08:13 AM
Nope. Just the car wanting to kill after it warms up.
Old 01-25-2012, 12:11 PM
ned032002's Avatar
ned032002 ned032002 is offline
When the vehicle is cold, it cycles in open loop until a few conditions are met. So once she warms up she then switches to closed loop. That may be where your issue is. Definitely check the MAF and o2 but I doubt you'll find an issue with the 02. My guess would be to start at the MAF. See if you can get your hands on another one to test out to see if that's your issue then get back to us with your results.
Old 01-25-2012, 03:21 PM
Will do. Thank you
Old 01-27-2012, 02:28 PM
ok one last question before i try o change the MAF. im trying to find a used one so i can save some money because a new one can be expensive. will a MAF from a turbo model be the same as the one from a non turbo model?
Old 01-28-2012, 07:29 PM
Holset powered 420a
Also dont rule out the ECU same thing happened to a friends car it would shut off when warm and turned out to be the ECU. Im not sure if the mafs are the same or not. I believe so but dont quote me on that.
98 Eclipse GS Turbo
2001 BMW 325i - DD
96 Windstar rough idle after warm up winterover Windstar 6 03-05-2012 12:57 PM
98 Windstar strats okay - rough idle after warm start on Humid day jayjp200 Windstar 4 11-03-2010 04:54 PM
1995 Astro rough idle after warm up..any ideas? tittymonster M Bodies 8 05-18-2007 10:06 AM
98 Expy has rough idle after warm kruser Expedition 7 03-13-2007 08:45 PM
rough idle after warm up fourreel '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 08-28-2004 10:43 PM
