Old 01-22-2012, 12:58 AM
madjack113 madjack113 is offline
1994 buick light control module
Hey I am really new to computers and chat, that said I have a 1994 Buick lesabre that the lights won't go off on.I have traced the problem to the light control module, went to junkyard and pulled several off.I am not sure I have right part some have 2 connectors some just 1.A mechanic at the yard said to unhook the battery so I don't blow airbag, there is also a guy at dealers who says part is on left, ones I pulled wre on right . I can't buy new to see what it looks like cause no one carries part Any Help would be greatly appreciated Jack
Old 01-22-2012, 03:34 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 1994 buick light control module
IIRC, the '94-'96 LCM was located under the drivers side dash, to the right of the steering column near center hump. It could also be located to the left of the column. I think it depends on which plant it was built?? It should have two terminal connectors. If you drop it down, there should be a part number on it for comparison. Let us know if you find the LCM & part number. BTW, I am moving this thread to the LeSabre forum to give it more exposure. Click Here for diagram.
Old 01-23-2012, 03:09 AM
Thank you so much for helping out so quickly,the guy at the dealership said this was where it was located. Thank you also for the diagram, this is my winter car and it has had a lot of electrical problems.One bad thing my father took out the wrong thing on left side of steering wheel and he is going to have a little trouble getting it back in. Again Thank You buy you a pop sometime Thanks Jack
Old 01-24-2012, 04:24 AM
Well here I am again, Dad took out what he thought was the LCM but it was the malfunction alarm.I really appreciate your help but we still can't find the part.I have several diagrams but they are in B&W.Is there any other way to tell where this part is, he is getting ready to put a switch in just so we can drive the car.I noticed on the malfunction alarm the part # is printed on the part I hope the LCM is the same way.Thanks again Jack
Old 01-24-2012, 10:37 AM
HotZ28's Avatar
AF Moderator Elite
You can look for the wire colors going to the module.
1994 Ford Probe Timing Belt Concerns pdallard Probe 2 01-26-2012 05:31 PM
4MATIC E320 - Stability Control Option tb30570 E-Class 0 01-21-2012 07:01 PM
