Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 01-20-2012, 10:39 PM
bdorris927 bdorris927 is offline
Banned
2002 lincoln ls check charging system
2002 ls with 111k miles. 2 months ago replaced battery and alternator because of alternator failure. last couple of weeks when i start it up in the morning cold and after starting the and the rpms are back to idle "check charging system" comes on. dash lights seem dim and heater doesnt blow as much as it should. after about 10 mins of driving the lights appear brighter and heat blows correctly and check charging system light goes off. its almost if theres not enough power then it surges after 10 mins and runs correctly. Is this a electrical or another failing alternator. it seems it only does this on the first start of the day. i would like to fix this problem before i try and sell. Dont know if it was a refurb or new alternator.
Old 01-21-2012, 12:28 AM
joegr joegr is offline
Re: 2002 lincoln ls check charging system
Aftermarket alternators don't seem to last very long at all on the LS. I don't think that you can get new Motorcraft any more either. You'll have to get a refurbished Motorcraft from a dealer.
Check Charging System mvansant LS | MKZ 7 10-16-2009 10:04 AM
95' Lincoln Continental / Charging System?? 1995Dezzy Continental 1 01-08-2008 12:10 PM
Check charging System marmerican LS | MKZ 1 01-27-2006 10:55 AM
windstar check charging system uehlein67 Windstar 4 08-05-2005 05:56 AM
Check Charge System j2hott23 Aurora 3 01-30-2005 11:36 PM
