Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 01-20-2012, 03:11 PM
jimmyespinoza85 jimmyespinoza85 is offline
Arrow H22A Accord Ex Auto with F22B1 Transmission. Help Needed!
I have a 94 Accord Ex with an H22A and F22B1 transmission. I used the P0F Ecu from a JDM Accord SIR Auto but the car runs good through 1st and 3rd but when in 4th or high 3rd check engine light comes on and then it starts shifting weird. When I use the F22B1 Ecu the tranny works fine I only have an idle problem of course it might be cause it doesn't read IAB. If anyone has any suggestions or knows the solution to this please help and explain briefly! Thanks everyone!
Old 06-23-2016, 05:04 PM
mcdavidbranson mcdavidbranson is offline
Re: H22A Accord Ex Auto with F22B1 Transmission. Help Needed!
Call Engine World Inc in Houston. BestJapaneseEngines.com They have the best JDM engines and transmissions. I have been buying from them for the longest time.
Old 06-23-2016, 05:14 PM
jasonnastley jasonnastley is offline
I would never use F22 transmission with H22A engine.
Old 06-24-2016, 03:02 PM
MikeCStig MikeCStig is offline
Yeah, definitely change out the transmission. Right now you're putting the 190-200 horsepower through an automatic transmission built for engines with 160 horsepower at the most. Basically you're overloading the transmission and losing horsepower. Your best bet is to find a transmission that actually matches the engine, and you'd be well served making it a manual transmission.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
98 Sport Auto Transmission Overheats gromittoo 1st Gen 95-99 1 08-06-2010 07:16 AM
transmission not engaging guys i need your help cyberfastpush Trans Sport 1 03-12-2010 05:58 PM
accord surging/jerking undriveable...urgent help needed!! elusive84 Accord/TSX/Accord Hybrid 3 03-20-2006 05:11 PM
H22 With F22b1 Transmission abex33 Accord/TSX/Accord Hybrid 1 01-04-2005 12:10 AM
