Go Back   Automotive Forums Car Chat > Buick > Regal
Old 01-19-2012, 09:35 PM
patriot777 patriot777 is offline
Smile Regal Speedometer
My traction control has been kicking in intermittently. Immediately after wrapping electrical tape on a damaged wire that goes to my speed sensor my speedometer went dead. I assume I made it worse by touching the already damaged wire so I ordered a new wire which is being shipped to me. Will it be bad for my engine or transmission to drive it with a bad speedometer? I don't know if it affects the computer or not.... The car seems to shift normally....the speedometer just stays at 0. Actually it appears to be resting under the "stopper" instead of above it????? Advice anyone?
Old 01-19-2012, 09:38 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Regal Speedometer
Won't hurt to drive with an inop speedo. If you repaired a sensor wire at a wheel speed sensor, that will not affect the speedometer, that is only for your abs/trac system.
Old 01-20-2012, 02:47 PM
Tech II Tech II is offline
Are you talking about a wire to one of the wheel speed sensors, or a wire to the VSS?
The fact that the needle is BELOW the "stopper", is NOT GOOD!
This can happen sometimes, if the battery is disconnected/connected with the ignition key in the "on" position.....if the dash "glass" has a hole for the push rod to reset the trip odometer, sometime you can slip a wire through that opening and rotate the needle counter clock wise back to zero.....
Old 01-24-2012, 01:09 AM
It was a quick fix. The wires going to the wheel hub (speed sensor) from the engine compartment were shorted. I swapped them out and the speedometer now works just fine and I know it is very accurate because I checked it with GPS. I ordered the wires online and it installed in just a few minutes. Thanks for the help.
03 Neon SE, speedometer and fuel gauge problem Toolwise 2nd Gen 00-05 1 01-19-2012 02:43 PM
03 camry has speedometer issue, can i just purchase a cluster with similar mileage or must chip be reprogrammed ? jerzstyle00 Camry/Camry Hybrid/Vista 0 01-19-2012 08:24 AM
97 regal LS jumpy speedometer needle caddiali Regal 6 10-27-2007 12:14 PM
1999 Regal Speedometer, Trip, Odometer Quit Working vandamja Regal 9 06-12-2006 01:33 PM
88 regal digital speedometer dumbfoundedme Regal 3 02-07-2005 12:50 AM
