Old 01-17-2012, 11:58 PM
SAMJP SAMJP is offline
Oil Pan Gasket
I'm changing the oil pan gasket on my 2003 silverado 4.8 2wd. I've gotten as far as getting the pan loose but can't get the pan pas the front axsel. considered raising the engine but can't find any jack points. anybody got a solution
Old 01-18-2012, 07:30 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Oil Pan Gasket
You stated you have a 2wd truck, so no front axle. There is a cross/support beam that runs between the frame rails. It just unbolts and drops out, maybe thats what you're after?
The Following User Says Thank You to gmtech1 For This Useful Post:
SAMJP (01-18-2012)
Old 01-18-2012, 12:11 PM
Re: Oil Pan Gasket
I've already removed the cross/support beam. It is the steering rack that is located about 1 inch below the shallow/front half of the oil pan which will not allow the front of the pan to clear for removal.
Thanks
Old 01-18-2012, 01:21 PM
gmtech1's Avatar
Re: Oil Pan Gasket
Rack is pretty easy to remove. Two mount bolts, pinch bolt at steering shaft, ground wire and hose fittings, disconnect tie rod ends. After the shaft is unbolted, turn the rack all the way to the right to shorten the left tie rod, then slide the whole thing to the right, then down and out. MAKE SURE THE STEERING WHEEL DOES NOT TURN OR DAMAGE TO THE SIR COIL WILL OCCUR!
Old 01-19-2012, 08:56 PM
Re: Oil Pan Gasket
gmtech1
After looking at the rack I decided to lifted the engine two inches. The oil pan came right out. I this had not work I would have had to drop the rack.
Thanks
Old 01-20-2012, 08:48 AM
j cAT j cAT is offline
Re: Oil Pan Gasket
Originally Posted by SAMJP View Post
gmtech1
Thanks
lifting the engine is what most do to get clearance. rack removal if your not experienced could be adding more problems.
use pins to guide the pan into the proper position use a few of the bolt holes to insert the guide pin.. follow the proper proceedure and torqure spec ...
make sure no oil is on the mating surfaces.
use mineral spirits/paint thinner to clean..
if the oil pick up screen is dirty clean ..
The Following User Says Thank You to j cAT For This Useful Post:
SAMJP (01-20-2012)
Old 01-20-2012, 10:08 AM
Re: Oil Pan Gasket
Ok will do. The gasket is a metal gasket with a 1/16 rubber flange, is it safe to use a beed of permetex red on outside of the flange to scure the gasket to the pan before reinstalling?
Old 01-20-2012, 04:19 PM
Re: Oil Pan Gasket
make sure the rear of the pan and the rear of the engine is flush/even.
tighten the bolts with a hand driver first check rear of engine cover for flush the evenly torque the pan down as below
tighten the pans bolts to rear cover to 106 in lbs...about 9 ft lbs..
tighten the oil pans bolts to engine and front cover to 18 ft lbs.
sealant is on the front cover / rear cover tabs that protrude into the oil pan surface.
SAMJP (02-09-2012)
Old 02-09-2012, 03:22 PM
Re: Oil Pan Gasket
Thanks jCAT got it done
Old 02-09-2012, 04:34 PM
Re: Oil Pan Gasket
good luck with this repair.
why do you think this failed to perform / leak ?
2000 GC 2WD - Remove oil pan without removing exhaust y-pipe? jrandallc Grand Cherokee | Grand Cherokee SRT8 0 06-05-2011 08:31 AM
Searching for a Ford Pinto oil pan Mr 14 Prozent Engineering/ Technical 0 05-25-2011 07:01 AM
Oil Pan Gasket? ken_man_1 F Series 8 12-03-2010 07:30 AM
valve cover gasket and oil pan gasket "seeps" georgecarnes Camry/Camry Hybrid/Vista 1 08-14-2004 10:39 PM
